daughter got me a bunch of jacaranda from where she works and wants me to make bowls for some of her coworkers. Too bad it’s a boring wood. So I added rim beads in this first one. Eight more blanks . . .
Working on a large Thai Red Amboyna burl last evening. I discovered a screwhole in the exterior of this bowl, and the resulting shape is related to removing enough wood to eliminate it. The interior will not be any deeper, because of this.....I would rather this not be the case, but to eliminate flaws, sometimes you have to do what you have to do.
You can see there is absolutely no tearout on this seasoned bone-dry surface direct from my turning tools..... zip, zero, nada! This is what I expect from myself with surfaces just prior to sanding. Sanding will start with either 220gt, or 320gt! I attribute the quality of this pre-sanded surface to "spiritual turning". Run a search for this in titles to previous AAW forum threads.....That is, if you are curious as to what I mean with this term.
View attachment 63631 View attachment 63632
Interested in the seeing the completed chair! I've built a couple stick chairs. They're pretty fun to build.View attachment 63643
Making octagon tapered stretchers for stick chairs.
Lathes, not just for round stuff.
I was pretty nervous getting it to the rough shape so that I could put the pewa in! The good thing with hollowing is that I'll be out of the line of fire if things don't go well.Even with 11 Pewa I would be nervous!
Will 11 pewa be enough to hold this together as a hollow form? We shall see..
I love walnut
Well didn’t have time at demo! To do any turningWon’t be on the lathe till Saturday at my first attempt of a demo
A star dish
A sliding headstock would be far superior, just work off the end, no screwy outriggers for your tool rests, no realignment problems, etc.This is where a rotating headstock would
be especially useful for my purposes.
Nice branding!Simple hard maple bowl, 5". I sanded to 320 then used Yorkshire grit. Next, a base layer of shellac and then Tried and True Original. I found I can get a fairly glossy finish with that combination.
View attachment 62347View attachment 62348View attachment 62349
About halfway there, no stability issues so far.Will 11 pewa be enough to hold this together as a hollow form? We shall see...
The symposium this past weekend was great, but I was definitely pining to get back on the lathe. Working on a fairly small, very curly Pecan calabash for a friend. I rough turned this quite a while ago and am now finish turning. Pecan is quite hard, and kind of a pain to sand, but when all said and done it is beautiful. Will finish with Danish oil and then will try a topcoat of varnish oil for the first time.
Thanks Bob, will do. I’ve never used this finishing method before, but I’m taking notes out of the Kevin Jesequel playbook.Very nice.
Please post the finished bowl. I never would have considered varnish over DO and I am interested to see the result.
Bob
FWIW, the Danish oil we are discussing is the Tried and True brand, which is just polymerized linseed oil. The varnish oil they make is the same with pine resin added. I have found the varnish oil too viscous to penetrate, so I apply it after two coats of the Danish oil, which does a better job making the figure pop.Thanks Bob, will do. I’ve never used this finishing method before, but I’m taking notes out of the Kevin Jesequel playbook.
FWIW, the Danish oil we are discussing is the Tried and True brand, which is just polymerized linseed oil. The varnish oil they make is the same with pine resin added. I have found the varnish oil too viscous to penetrate, so I apply it after two coats of the Danish oil, which does a better job making the figure pop.Very nice.
Bob
