• March 2025 Turning Challenge: Identical Bowls or Plates! (click here for details)
  • Congratulations to Joseph Bernard for "Working Spider" being selected as Turning of the Week for March 3 2025 (click here for details)
I was given a few years ago some Azobe. An African wood used for crossties and bridges now blocked from harvest. The man who gave it to me was a CEO of Southern Railways. They used this wood for crossings and he had several ties. Would not even want to think of lifting one . I made this cup of part of the first piece he gave me. It is very hard and being tropical I just applied wax.
Terrific
A mastery of the 3 cornered bowl taken to nes dimensions
Appreciate the compliment, but I wouldn't call it mastery... It isn't perfect (One corner is just a bit thicker, maybe 1/32 - 1/16 inch , because I didn't get perfect center) and I didn't quite get it to the shape and continuous inside curve I was shooting for (I chickened out before getting too close to those spinning points, so couldn't make the curve as even as I wanted it to be) , but I'm sure there'll probably be several more down the road (I might do one as a follow along..) ... But then maybe I'm being my own harshest critic....(as I tend to be)
That’s awesome, Brian! Great design and execution. Thanks for following up.
Thank you for the compliment! - And, Welcome re: the follow-up :) (Not too shabby for a Harbor Freight lathe and BB tools... kinda goes to show a top dollar lathe and $250 gouges don't make a better turner...?)
Back to it after a week of vacation in Denver. I found a log that had been laying for a long time. I did a little happy dance when all that orange sawdust started flying.
Pretty severe tool marks. Hard, hard, wood and NE are a challenge.
I'm not sure what to do with the rim. The bark was long gone so what remains is cambium, etc. Suggestions?
the interupted cut is one of the hardest to do well. You have done ok. David Ellsworth is terrific at it. mastering his flute up cut on the inside wall is one way to eliminate tool marks.
you can take the bark off. A lot of work. Then you can color the top edge with prisma pens of similar.
remember to use a color(s) that will look good on dark brown.
Spheres…
All these ideas and not enough time in my day. I'd seen a circle cutting jig do that before but you're giving me some ideas on a little coffee scoop I made the other day.
Care to share some details? Spindle need to be round before you start? Any certain speed on the drill? Slow or all out?
View attachment 61023View attachment 61024
That looks like a familiar wood..... Only I made a long round thingy. Not round in the pic yet though.
Scoops look pretty good Sam.
I've made quite a few, I start with turning the round head (turning them by eye and just outside measurement) and what I want the handle to look like, ( easy to sand them flat and shape it some, I settled on what I call the beaver tail shape.
Band saw the piece into two identical halves, then I use a jig that will hold the halve securely, I used just apiece of 2X?, and turned a recess that would accommodate the scoop head, clamp the handle down an also used a screw head to keep the end down, just hollow it out.
SIMPLE BUT IS WORKS FOR ME.
Pretty much the process I used.. Except I followed the "we don't need safety devices" rule of thumb. I just jammed in a hole turned in scrap and let her rip. Didn't spend a whole lot of time on them and if you look closely one has a design modification in the bottom, We'll call that one an egg yolk separator.
Hind site your little fixture would probably work better especially if I were to make the ball with a circle cutter for uniformity.
Finished up the Jarrah burl platter last evening.....still very wet with D.O.....approx 10 1/2" x 3/4".
Hi Sam,
Yes, with a round spindle we get less vibration… Regarding speeds, it depending on the de spindle diameter as you know. In that case, around 500 rpm on the lathe and about 2500 on the drill. The apparatus …IMG_6742.jpeg
Hi Sam,
Yes, with a round spindle we get less vibration… Regarding speeds, it depending on the de spindle diameter as you know. In that case, around 500 rpm on the lathe and about 2500 on the drill. The apparatus …View attachment 61065
That's quite the linear rail on there!
Kind of like Jim above, these aren't on my lathe anymore. I'm making a German smoker (Räuchermann), but in the form of a large tree. Admittedly, it is a swap piece that I am a couple of months behind on. This is one of those projects that ended up being more work than I anticipated (and come with a bunch of unfortunate delays). I'm chugging away at it. Here are a few of the tree branches:
These are made of Maple, Cherry, and Birch, and they're turned, cut apart, reassembled, and textured. Admittedly, I did use a few dowels, which cut out some of the turning, but most of these I turned from flat stock (the large pieces laminated). I still need to add another couple of layers of texture, and then I'll color these. There are several other components to this project, but this is just a sneak peak. Partly to contribute to this thread, and partly to give me a bit of extrinsic motivation. Each of these three is about 7"ish long.
With the recent threads on turning square bowls, I renewed my interest in a project I had been putting off for many months, so finally made use of those 12" x 6" x 2" or so offcuts I'd gotten in an "assorted box of offcuts" deal... Key points: they have to be cut precisely square and glued up perfectly (on faces flattened first on my planer) to get a perfect (or nearly so) cube.. Most of the time spent was in getting it perfectly positioned to cut the initial tenons.. This is after day #3 of careful cutting - Stopped at this point because I started to feel a little tired, and as we all know, it isn't good to try to keep going when you start feeling tired... But when it is done, Should have a fairly nice, slightly less than 5-3/8" 6-pointed bowl... View attachment 60807
Very nice, looking forward to the final result. I have been interested in doing some flat bowls.
Bob
12" sweet gum. This whole tree had terrible ring/cup shake, so the few pieces I did keep require pewas to be able to turn. And I somehow used all pewas I had cut with the wrong grain orientation, but they held!
Some sort of fruit wood. Chokecherry maybe? Cuts very nice
Chokecherry does not get that big however black cherry may get that big if the growing conditions are right. The fruit of the chokecherry and that of black cherry are mostly identical. The difference can be seen when the white blossoms come in spring, and the bark on the CC is lighter then the BC bark. The grown over wood pecker tracks are typical of BC growing in the north country.
A friend gave me a couple of chunks of Sumac a long while ago (not sure what species). One of those situations where the wood looked so crummy you almost want to say no. BUT, I had never turned Sumac, so I couldn’t pass it up. It sat, and sat, and sat, until today when I decided to turn a mini-calabash out of it. The wood was super dry, super soft, hollow-pith, but very beautiful. Green and brown colors and wide growth rings. Here are before (as I received it from my friend), during, and after shots:
A friend gave me a couple of chunks of Sumac a long while ago (not sure what species). One of those situations where the wood looked so crummy you almost want to say no. BUT, I had never turned Sumac, so I couldn’t pass it up. It sat, and sat, and sat, until today when I decided to turn a mini-calabash out of it. The wood was super dry, super soft, hollow-pith, but very beautiful. Green and brown colors and wide growth rings. Here are before, during, and after shots:
Nice! The grain looks like a texturing opportunity from my vantage point!
Cheers,
Barry W. Larson
Calgary, Alberta, Canada eh!
Cheers,
Barry W. Larson
Thanks Barry! The grain is interesting. Even though the dark bands are more porous, all of the wood is pretty soft. I don’t think you get much of a cool effect like with conifers that alternate hard and soft wood. You could probably get a pretty dramatic look overall with wirebrushing though. BUT, I’ll let someone else go that route haha
Made one the other day so I thought I might as well make another from the leftover wood. hedge apple.
It's maybe not obvious but it's a cane. I hadn't put any decoration on yet in that pic.
Chunk of antler for a handle.
I have been thinking about doing one for myself as well. I would love to see the finished product.
Thanks,
Bob
Thanks,
Bob
Not a problem. Don't expect too much though. Only the second cane I've made. My spindle turning up to those has been snowmen and Harry Potter wands with some kitchen utensils thrown in.
It's hard to get a nice flowing design with an odd shaped antler. I'm thinking maybe a glass door knob for third one. (have lots of hedge apple)
