  • Congratulations to Guillaume Fontaine for "Nebules" being selected as Turning of the Week for April 6, 2025 (click here for details)
Couple of CA black Walnut burl bowls were roughed last evening. Should have wetted the surface to show off the grain and colors in these two.....they are outstanding examples!
Both are over 35% MC.....very wet. It'll be a year or so before I can do the 2nd turn...
=o=
Did a couple bowl feet this evening.
Currently experimenting with some acrylic paint pens to do a permanent inventory number. (Thanks to @Ed Davidson for the idea!)
I've found that you really have to be careful with the buffing to prevent the process from ruining the numbers, but with some practice, it can be done.
The paint needs to dry for 24hrs before a sealing coat of DO is applied.
I also re-wired the dash and replaced the input voltage wire to the distributor of my 1928 Model A Ford Pickup truck today! I think this fixed my hard starting issues.....fingers crossed! It was getting dark, so couldn't test drive it today......soon!!!!! :)
=o=
View attachment 73723 View attachment 73724
Odie….your bringing back old memories! I had a stupid attack and sold my ‘33’ flat head V8 about 10 years ago. Still miss it🙁
Last evening, I roughed these two:
Olivewood and Thuya burl.
Both had a high MC of around 30%.
I suspect the Olivewood will stabilize before the Thuya burl....we'll see.
Photos taken just prior to applying the anchorseal.
=o=
View attachment 73849 View attachment 73850
How does the Thuya sand for you? I find it clogs really bad. Both are beautiful!
Well I saw a picture yesterday of an enclosed rim ( I think that’s what it’s called) bowl and had to try my first one tonight.
I surprisingly kept the wall thickness consistent at less than 1/4”. It measures 9-1/4” tall x 14” at the widest point. I’ll sand it tomorrow, remove a few tool marks, and possibly remove the tenon. I used my Thompson and Jamieson 5/8 bowl gouges, negative rake, and the dreaded bottom bowl gouge…..and should have came here first to ask questions or watched a video, and started with a smaller size…. lesson learned. Criticism welcome!
Dan, you might never see that super gem again, but the market for classic and antique cars is always bringing up new prospects for those who are interested. Us old geezers don't live forever, you know! :) Even though I've put in a lot of effort with Orville, some of his past owners have put a lot of elbow grease into what he is now. I found an old Oregon registration behind the seat from the 1950's, when he used to belong to a woman, believe it or not! I wonder what her story is....or was......? :)
Yeah, that's how it's been for me, too Gabriel.
I keep a rubber belt cleaner handy and use it often for woods that clog easily.
=o=
No criticism—just praise.
Yah. Looks good to me!
David, awesome looking bowl. Great proportion and shape. I am going to try some of these after finished cutting walnut stash. Would sell like hotcakes as far as I am concerned. What finish would you use? I currently have a ton of Ambrosia Maple waiting to be cut. Did you do anything to keep the bark on. First turned?
This one will be once turned and we’ll see how it looks when dry. My concern was the shape and proportion.
On the finish, I’m thinking walnut oil or danish and also considering wipe on poly, still thinking about that.
It was a little tough with the bowl gouge, had to go at about the 1:00 position and take it slow for the top curve and extended reach. Should have moved the headstock to the end of the lathe but I’m hardheaded 😁
I love it! Nice form, beautiful wood, bark is great (I like the "fish" swimming around the side. :) Well done!
Oil will prob darken the wood some (maple?) but bring out the figure. If you have an offcut you could sand a section and test the oil first.
I've heard different names for a rim that is inward rather than straight or flared out: closed, inverted, others. I haven't heard "enclosed" yet but that seems as good as any!
Although sometimes a bit more challenging to turn, I'm partial to bowls and forms with some sort of closure at the rim, even if the rim is just turned in a bit - I like those forms far more than the more typical bowl shapes flared outwards inside and out. (easier to turn that way?)
This was the first NE bowl I ever did, maybe 20 years ago, from green elm, tiny flared foot, very slightly curved upper sides, oil finish:
This one is only about 5" across. I remember the inside was more challenging than the outside.
I try to experiment and make each shape quite different. Next time I think I'll try a shape more like yours!
Yes maple, I like the look of walnut oil on maple. With the closed rim it will be harder to dry buff on the inside with my buffing wheel so I’ll do that by hand on the lathe. Turning the inside is harder than most bowls, had to stop and clear shavings often, used mostly the 60* gouges but also tried the 55*. If the rim was closed more I don’t think either gouge would have worked without hitting the other side of the rim.
I thought about putting a 40-50* grind on an older gouge but was able to complete it with the 60*.
I like the look, was concerned about the shape since I had only seen one but I’m happy with it and plan on a few more to refine my technique.
It does look like a whale swimming on the front on the bowl😁
@David Wyke when I do a bowl similar to that I start with a 40/40 gouge until it won't make the turn, which isn't too far after you start to turn. Then switch to a 60 degree gouge for the rest of it. Once I started it behind the lathe turning left handed then went to front of lathe and used right handed cut once the turn started. I think the best thing for one like yours would be try to move the headstock to end of the lathe.
I did move to the back of the lathe for a cut or two and thought a 40/40 would work better to start with. I agree moving it to the end of the lathe would have been better.
For clearing shavings, has anyone tried one of these?
A son gave me this for Christmas. I knew it was powerful but just now I held it 12" from my wind speed meter - clocked at over 45 mph!
For those without an air compressor handy one of these might help with clearing chips.
I use it to blow dust from screens and circuit boards and dirt from various things around the farm.
My wife bought a similar one. USB charger and pretty powerful.
Gorgeous wood and form, David. I don't think you needed to watch any videos; you should actually DO an instructional video on this!
I wanted to do a live-edge pedestal bowl in Chinese Elm. I had let this one get a bit punky on the outside, so I lost the bark, and it has a few bug tunnels I have to decide either to fill or leave as character marks. that pedestal, finish the bottom and outside, and flip it into that recess to finish today. (Oh, and the "hairs" are from the chip brush I used to brush on sanding sealer before doing a little strategic gluing.).20250327_115501.jpg20250327_174848.jpg hope to refine the curve in
Nice, Phil-I turn a fair bit of curupau, often into square jewelry trays from those same square blanks. If you've never turned it before, try to get the cleanest finish you can off your tools, as it's harder than peace in the Middle East; it just laughs at sandpaper lol! (But also due to its being so hard, it responds well to an NRS finish.).
Not sure if I'll be able to pull this one off. Dogwood. I'll be getting rid of that shoulder on the chuck side.
Looks like success to me! Great, you win the Dogwood Prize. :D
I plan to dig up a dogwood stump in a neighbor’s yard next week. If there is any too challenging for me I’ll drive over and bring it to your place!
Wow, dogwood is another super-hard wood, and cracks more than any other I have turned, but takes a glorious creamy finish. Nice work, Kent!
Dogwood is one of my all-time favorites! Yes, it’s hard and very fine grained and finishes beautifully. In general, I find harder woods tend to be easier to get a good surface, often needing little or no sanding.
I only turn dogwood I’ve cut into blanks and dried. Warps like crazy if turned green or even slightly damp. It will certainly crack and split badly if green and left in the round. It’s usually a small tree but I was able to make some good-sized blanks from a couple of larger trees I had to take down, some about 8x8x4” for small bowls, a bunch for lidded boxes, ring keepers, mallets and such.
Some examples of old stuff:
Cocobolo and Dogwood pepper/salt mills. Use these every day for 18 years now.
Betcha can’t guess which one is for the salt. :)
Some Dogwood spindle blanks drying. Dry slowly due to density and very fine grain.
The smaller stuff makes great long, thin spindles (very strong), finials for ornaments, etc.
In general, Dogwood with some sap wood and some of the darker heartwood is difficult to dry without cracking.
It’s feels and turns very much like Privet (which is even harder to find sizes big enough to turn.
I discovered that dogwood from a stump sometimes has wonderful color and if the tree is cut and the stump in the ground for a long time can spalt nicely.
If in the area some day, drop by and I’ll give you a dry blank or two.
This small finger top from dogwood, an experiment direct from the spindle gouge, no sanding or finish.
John, maybe someday I'll be as up on my dogwood game as you. That said, I did manage this candy dish a few years ago that just had crazy cotton candy swirls in nearly every color of the rainbow; (it's probably brown now lol). It was one of my first bowls; I gave it to one of my all-time greatest students who got the highest score in his class on one of our AP practice exams. . Before I retired, I used to give my students little pieces like that as prizes in the contests I was always running haha.Dogwood Bowl.jpg
This elm burl has quit loosing weight so it's time to finish it. The bowl is about 12" and pictured on the lathe I wiped it of with mineral spirits to show off the burl. There are a few voids close to the rim, I didn't fill them with epoxy, but one that seemed a little sketchy for breaking was reinforced with epoxy on the inside of the void. Because of the different voids I left the thickness at about 1/2".
I decided to carve little feet for the base (go figure). Got a ways to go; I use the tape as a guide that I'm getting close the bowl and reduce scratches to sand out.
