I'm guessing that with Pau Santo, the interlocked grain combined with its great density has something to do with the difficulties I was having with this wood. Since you can't pick and choose the best direction for cutting the end grain in a cross-grain bowl, the goal of achieving "the perfect cut" becomes an almost impossible task.....and, if there is any tearout at all, the sanding is just as frustratingly difficult.
=o=
Last time I turned mimosa/silk tree, I got congested and started itching.... Nevermore!
Since Robert posted his acorn box in the Gallery I'll post a picture of my effort here (not gallery material).Turned my first acorn box had some ash and black walnut laying around
Made jamb chucks for both in order to finish them.View attachment 74375
Nice job! I am flatteredSince Robert posted his acorn box in the Gallery I'll post a picture of my effort here (not gallery material).
Box body is White Oak with a Black Walnut lid (cap). Lid is spirally textured. Polymerized Tung Oil finish with silver metallic wax on the textured area. The metallic wax is less apparent in the picture. Base is the end of a circular sawn Black Walnut board I left rough on the surface the acorn is set in. This was a fun little project (Thanks for the inspiration Robert); I think I might explore this idea further.
Cheers.
Barry W. Larson
Calgary, Alberta, Canada eh!
Beautiful, Gary! I'm finishing the bottom on a nice curly maple little platter/candy bowl I guess, and considering almost that identical finishing regimen. I have used pretty much every oil-based finish over Yorkshire Grit. I assume no issues spraying lacquer over it?Still on the lathe, waiting to finish the topside. Labeled as cherry burl. Sanded to 400 grit, shellac sealer, Yorkshire Grit then spray lacquer.
What species, Phil-I imagine if it was Fraser Fir it would smell like Christmas too! (Incidentally, I was at GotWood in Donalds, SC with Tim Tucker yesterday picking up some wood for our club classes as well as some for our personal use of course. Anyway, Brad had a stack of camphor burl squares that were stunning to look at, and smelled like Vicks VapoRub. I had never smelled it before. He wanted more for them than I was prepared to spend, but next time I definitely want a square or two-got to sell some stuff!).
Not sure on species. Got it from a sister who had it in her yard ready for burning.What species, Phil-I imagine if it was Fraser Fir it would smell like Christmas too! (Incidentally, I was at GotWood in Donalds, SC with Tim Tucker yesterday picking up some wood for our club classes as well as some for our personal use of course. Anyway, Brad had a stack of camphor burl squares that were stunning to look at, and smelled like Vicks VapoRub. I had never smelled it before. He wanted more for them than I was prepared to spend, but next time I definitely want a square or two-got to sell some stuff!).
Your forms are looking great! How’s the hollowing going? That was my toughest part. Also do you hollow by hand or use some type of hollowing system?Turned a couple of small hollow forms today. I finished the bottom on one, wrapped the other one in plastic and will finish the bottom on it tomorrow. They say practice makes perfect and I need the practice on hollow forms
I still don't have any idea what kind of wood this is. Anyone have a suggestion of what it is?
The first picture of the inside of the bowl it has been wiped with mineral spirits.
James, to my eye, it looks similar to honey locust. Could it be?
It’s going fairly good. This was some 8” chunks of maple I had and thought they would be good practice, going to turn one more today. I use the Lyle Jamison system and it works good, just have to battle the laser going in and out. I really don’t want to use a camera. I’m going to search for a better laser to attach. I also need to get a couple of Trent Bosch cutter/arm to try on it.Your forms are looking great! How’s the hollowing going? That was my toughest part. Also do you hollow by hand or use some type of hollowing system?
I've run into a few pieces with the interlocking grain. You're right, they are a PIA to turn. Mostly I've encountered that when doing spindle work and smoothing with a skew when the chip takes a nose dive.
It's still a perfect form like all of your work.
That piece of cherry is now a 19 5/8” diameter platter with a slightly raised edge for an interactive piece for the art exhibit I have coming up in May. I plan to make about six to eight tops out of different species of wood, and behind the platter will be a rack to hold the tops, made out of the same species of wood with the name and a winter silhouette of each of the tree species lasered into the rack.
None so far. I make a point of buffing it off really well before spraying.gorgeous wood and bowl-I'd love to get a hold of some of that wood! It seems quite expensive when you can find it.
The signage will encourage them to spin a top or two, and then replace them in the rack once done so they are ready for the next person. (I plan to make a batch of each on the off-chance that some walk). The title of the piece is “Tree Tops”What a nice idea. (I organized a top-spinning contest at a club meeting once and have had some impromptu spinning contests at social events - top wars are fun with a very shallow dished surface!)
The rack should be nice, but with an interactive piece how will the tops end up back in the right spots?
BTW, I love making finger tops and people love getting them. I’ve made many 100s over the years and given away most of them. Also, for those who don’t want to turn a surface a metal or wood cake stand can work well - those often have raised edges on the circumference. We have one like that made of stainless steel, great for spinning tops!)
I don't have a UV light but, I will get one. Thanks for the information.Do you have a UV light/flashlight? (I keep several here for wood ID, checking eggs for incubation reasons and for some other things.)
Another item that works well - I have glass plate (turntable) from an old microwave. Only downside - if large (like mine) it is a little heavy.Also, for those who don’t want to turn a surface a metal or wood cake stand can work well - those often have raised edges on the circumference. We have one like that made of stainless steel, great for spinning tops!)
I like turning hickory and you’re right, it’s hard to get a clean piece.The recent tornadoes in Mississippi got close. We did have some high winds where I am at. An 18” hickory came down in a hollow. This is one of 9 bowls that I got out of the trunk. It’s hard to get a clean bowl out of hickory here as there are lots of knots. Hope this one holds together!
