I grew up next door in South Dakota. I remember those winters.
Well the temp is rising - yesterday the temps kept rising tell it was about 15F at about 6:00PM and continued to rise till now it is 17F so as the day goes on I expect that it will continue to rise.
My wife grew up in the James river valley along US12.
This is proving to be very slow and very hard. Its well dried and seasoned, but then I realized its from a tree that has a high silica content. How high? I am not sure but it sniggers at my 1/2 Thompson gouge and I have had to turn to my Carbide tipped gouge. But the finishing is proving to be the slowest even with a tungsten grit files, lol I am going through sandpaper at a rate of knots not seen on Blackwood before.
Miniatures are fun because you can turn 10 in 10 minutes, maybe come away with 3, and in an hour you might have one that has an okay shape.
After seeing the interview with @john lucas I've come to appreciate the idea of doing miniatures. That will be in the future though, as i don't miniatures is the right work to learn turning skills with.
Gregory
Gregory
I just reread the thread about the interview! When I saw it before I thought John Lucas was hosting Pat, and I wasn't familiar with Pat, so I didn't look too far into it. I am dissapointed that I missed it, I would have loved to see!
This piece of wild pecan was harvested from a blow down on my property in Grenada Ms. The first section had wind shake and it went to the burn pile. This piece from the second section showed what looked like the same thing. Put it in the burn pile last April after once turned. It caught my eye today and after examination I decided to give it a try. Turned out pretty good. 12”x 2-1/2.
It's been a minute since I posted in this thread, but I was so busy turning out stock for my 1st full show season up to Christmas that I just didn't have much time for taking and posting pictures. This falls squarely in the category of "Be careful what you wish for," and I wouldn't have it any other way!
Anyhoo, here is a 12"x6" live edge bowl in Bradford Pear that I am in the process of finishing up. It developed a couple of cracks in the drying, which I was able to stabilize with colored epoxy. But it was pretty cool that the bark held on without any CA whatsoever, even on summer-harvested wood! Obviously I need to bring that bottom ring in and flatten it out. I've been playing with a flared bottom ring lately; it looks great when I get the proportions right.
Here it is after power-sanding to 180 (and lots of hand-sanding to chase out any slight humps and low-grit scratches, plus burnishing with 0000 steel wool on the lathe). I'm loving watching the curl come into view as I get closer to finishing! I plan to go to 400 on this one (maybe 600 if my back and shoulders give permission lol!).
As it will be a wedding gift for my son and his lovely new wife, I plan to pull out all the stops and do probably 8 or 10 coats of TruOil gunstock finish with lots of follow-up burnishing once it's cured. For any of you who turn any kind of pear or similarly hard wood like dogwood, you know how much work is needed to get a true gloss finish, as it will show even the faintest scratches, so I am really taking my time to chase them all out before I leave 180. That for me is the "Do Not Pass Go" grit when I inspect it under my strongest lights, or better yet, in low afternoon sunlight on my back deck. Now if I can get my new vacum chuck set up soon and my brushed copper medallions I have on order, I think this will be the perfect 1st piece to try that on. We'll see.
Thanks for looking! Aaron
Trying to make a new offset turning jig for making pendants. Getting close. If it works out there will be no need to remove to orient the blank to any position or to offset. Ready for me to make a trip to the hardware store but it's too late on a Saturday afternoon.
I've envisioned a very similar system for translation based on that picture. I see the guide rod abs threaded rod are missing currently (or whatc looks like features for them). I'm curious to how well it holds during turning and wish you great luck.
Gregory
Thought I might attempt the Jan finial challenge, so sharpened my skew and turned my first spindle since I took Woodturning 101 in 2021. Whether I can get it off the lathe is another story lol.
I think this might be wenge, but I’m far from sure. Anyone have a guess?View attachment 71092
Wenge, or could it be Katalox aka Mexican Ebony?
First item turned on new lathe. It's just a little ring bowl. I think it's cherry but whatever wood it is, it's from my property. I finished it with 50/50 oil. Now that I know the lathe works properly I'll move on the larger pieces.
So what did you get?! I'm a bit behind on threads, maybe I missed it if you posted about it already. I get a vicarious thrill when others show off their shiny new lathes!
My FiL gave me his refurbed Powermatic 90. He purchased it from a gentleman in the early 2000s who liked to buy old powermatics and fix them up. This one has a custom cabinet, it's swing increased and a VFD motor added.
Nice-that old PM looks like a tank, very solid-looking!
Switch off the walnut to see what the maple I got last week was going to look like. Had a large crotch piece that I wanted to try. It ended up have two offset piths in the top section so both bowls will have a pith in them. Hopefully it won’t crack but there was no way to cut the two blanks with out getting the pith in them. If they crack too much I’ll fill them and they will become give away bowls. Currently 14”x 7” but should finish out once dry at 13.5” x 6.6”
Wow, lots of nice curl and ambrosia in that one, David. One thing I learned at my craft shows last year was that if I had a table of varied American hardwood bowls and other items, it was interesting to watch people peruse my merchandise and their eyes light up when they landed on a nice ambrosia piece. I have learned to always keep a couple of them spread around my table, with one on a turntable front and center. Then if I pick it up and hand it to them and start my spiel about ambrosia beetles and the tunnels they bore and the patterns they leave behind, it often results in a sale.
I talk about the beetle also and most people don’t know what the beetle does. I sold several ambrosia bowls at my last show and a couple were $220 each.
Really beautiful piece of wood David!
