Wooden Teapot Project
Time to cut the body! This step has been looming over me for a while, as it's the last stressful part of the project (stressful in the sense that a total disaster could occur). First I needed to lay out my cuts in a way that left my lid exactly at the top--somewhat of a challenge with a round-body object. Dividers to the rescue! Because I took the time to make sure I had perfectly equal halves and also centered my glue line on the exterior, I had a starting point. I needed to mark 90 degrees from my glue line, so I used my dividers to get close, and then made two pencil marks the same distance from the glue line. Then, I marked a line in the middle of my pencil marks, and used a square to draw a line that connected both sides of the teapot. ind of a weird thing to explain, so hopefully the following image clarifies my strategy. The photo shows dividers on the glue line and my first mark. the next step was to put one side of the dividers on the glue line opposite the lid and mark with a pencil where the other point landed.
Following this, I measured 110mm down from the top--this is past the center point, so will allow the body of my teapot to curve under a bit. I then used my dividers and my middle pencil line to draw boundaries for my cut line. I opened my dividers so that one point touched the pencil line, and the other point touch a spot on the edge 110mm down from center. I marked this point with a pencil, and then repeated this three more times (with the dividers set at the same measurement). Then it was just a matter of connect the dots with a straight edge. All of these steps gave me a cut line that wrapped around the body, and once cut would establish the lid perfectly on top.
Time to cut. I don't have a band saw, this is way too big for my scroll saw, and I couldn't be bother to clean off my table saw (that's a half joke--I wasn't too keen on trying to cut this cleanly with my cheap table saw). I decided the best course of action would be to use my flush cut saw. It has a narrow kerf and fine teeth. Also, the nose is slightly angled and lacks teeth, so as long as you move slowly you can get a clean, straight, and square cut. Here is a shot with the nose recessed into the cut line--you should be able to imagine how this helps saw on track.
After some sawing, I finally made it through, with just a little bit of cleanup required. Here is the glory shot of the teapot sections separate:
The smaller section is waste (or something for a future project, of course), and the larger piece is the teapot body.
To clean up the cut edge, I used the oscillating belt attachment on my spindle sander. I covered both flat side of the teapot with painter's tape to protect the surface, and then slowly sanded, flipping the body over frequently.
After a few minutes the bottom was fairly clean but had a tiny bit of wobble, so I spent a minute or so sanding the bottom against a flat surface covered with sandpaper. Clean! I then marked a line around the bottom of the teapot, as well as on the interior. This line indicates the waste line for a rabbet I needed to cut away for a bottom. This would have been a relatively quick task if I had a router table. Sadly, I do not, so I used a couple of carving bits to hog away most of the material (a Kutzall dovetail burr mentioned above, as well as a fluted cylinder with flat top). Following these, I used a skewed carving chisel to clean up the edges.
I refined the border a bit more after the photo, and lightly sanded to smooth everything out. Not perfect, but good enough for this purpose. I then cut a piece of 3/16" plywood to fit the recess. I wanted to use plywood to ensure that the bottom wouldn't move seasonally.
I decided to use epoxy (JB Weld 5-minute) to attach the bottom to the rest of the teapot. This is a good gap filler, and will provide a stronger and more permanent hold than anything else. I'm also planning to drill and insert some dowels for additional support. I mixed up some epoxy and spread it liberally on the surface of the rabbet.
After I inserted the bottom, I used a toothpick to run a small bead of epoxy around the junction so that any gaps would be filled. I added a couple of clamps (took a bit of finagling), and the following photo shows the current state of the body. After the epoxy cures, I will add the dowels mentioned above, sand the bottom flush, and then go through the sanding/CA protocol is Used for the rest of the teapot body.
Aside from the body work, I also drilled holes and added 1/8" dowels to the lid handle, body handle, and spout. The dowels are glued with titebond 2. Prior to this I also spent some time refining the shape/surface of the handle and the spout.
You can also see that I decided to cut the lid handle down a bit. I didn't like how much the hand protruded from the lid, so I went with something a bit closer to the traditional form. After I cut the lid handle and drilled the dowel holes, I inserted some temporary dowels with and used a sharpie to color the end black. I then pressed the black dowel ends onto the lid. This leaves reference marks for where to drill.
Following this, I measured 110mm down from the top--this is past the center point, so will allow the body of my teapot to curve under a bit. I then used my dividers and my middle pencil line to draw boundaries for my cut line. I opened my dividers so that one point touched the pencil line, and the other point touch a spot on the edge 100mm down from center. I marked this point with a pencil, and then repeated this three more times (with the dividers set at the same measurement). Then it was just a matter of connect the dots with a straight edge. All of these steps gave me a cut line that wrapped around the body, and once cut would establish the lid perfectly on top.
A hand saw?! Wow, pretty impressive. You seem to make exceptional work with minimal tools! Although once you get a bandsaw you will wonder why you never had one!
Thanks Gabriel!! Some of the flat woodworking skills paid off after all, hahaha. Band saw has definitely been on my list for a while; alas, I’m a wonderful procrastinator! Soon though. 😃
Last night I was able to finish the bottom of the teapot. This is a shot of bottom after the epoxy had cured. You can see that I also added 6 dowels for extra support. The dowels are 1/8" diameter, and likely maple or birch. These are the same that I am using to attach the handles and spout. I glued them in place with titebond 2, and then used a flush cut saw to trim close to the surface.
I then sanded the bottom flat-ish with my oscillating belt sander mentioned before. I say flat-ish because the sander puts just a tiny bit more pressure on the edges than the center when you have a solid surface. This is visible in the following photo.
So, after the belt sander, I sanded on a flat surface. Yesterday was my luck day at my turning club's meeting. I won some cool wood in the raffle, a woodcraft gift card, as well as the bring-back box (I received a piece someone made, and will make one for someone else to receive at the next meeting). The gift card was great, as it took a chunk of money off of something I had been wanting to buy for a while--a granite surface plate! Dead flat (within something like 0.0001 mm/m), and much better than my previous "flat enough" piece of wood. Ha. I laid a piece of 180g sandpaper on the surface plate, sanded, wiped the bottom of the teapot body (dust included) with thin CA, let the CA cure, sanded again, and repeated the whole process.
Here is a shot of the bottom of the teapot body finished:
Awesome thread, Michael! Looking forward to the next installment. Quick question: Why 5-minute epoxy over Titebond III to attach the bottom?
Thanks Jaramiah! I'm sitting in the Denver airport, waiting to catch a midnight flight home. Itching to get back to work!
The reason I used epoxy is that it is a good gap filler. My panel and carved rabbet were pretty close, but not exact. The epoxy got me the rest of the way there. Also, I am going to be doing some pyro and carving, and the epoxy should keep a more natural surface at the junction than titebond. If my joint was super tight all around, I probably would have gone with titebond.
Hi everyone! I got back home from Colorado yesterday, and manage to do some work on the teapot. --Side note, if you every have the chance to go to the Rocky Mountain Woodturning Symposium, do it. Trent Bosch and crew put on an amazing event.-- Prior to heading out of town I had drilled holes for the main handle and the spout (following the same method as above). Unfortunately, I had to finesse the fit a bit. The handle holes weren't too far off, but I did accidentally drill through the wall completely and had to create a new bottom to each hole with some CA glue and a tape dam on the interior (so the future epoxy won't fall through). No biggie:
The spout holes, however, needed quite a bit of repositioning. I had positioned the spout a bit too high and off center, so the holes (that won't be visible at all) sort of look like a butcher job. I also accidentally scratched the surface when I was widening one of the holes a bit. D'oh! Fortunately, that can be masked, so not biggie. Part of this follow along is showing the good and bad, and the ugly, and this is about as ugly as it gets:
In the image above, the final holes are the four-hole set that is the furthest down and toward my thumb (left side of photo). Again, none of the extra holes matter, as they won't be visible at all. The small holes in the photo were the original, and were fairly clean, but as I studied the teapot mocked up, I knew I needed to fix. You can see the change in the photos below. The first is the initial placement of the spout, and the second is the final placement--subtle change in position, but a dramatic improvement. You can see in the first photo that the top of the spout comes up to about the 1/2 to top 1/3 of the handle. This just didn't look right, so I lowered it by about a centimeter. Now I'm pleased. You can also see some of the surface embellishment, which I will describe in the next post. Here is the initial spout placement:
Here is the final placement:
Like most things, subtle differences can make or break a piece.
My plan for embellishment is to make the teapot look a bit like there is a ceramic shell that is breaking apart to reveal the true wooden nature of the object. It is a lot of work, but I think (err, hope?) it will look cool in the end. I first studied a lot of photos of crazing ceramaic objects to help me replicate the effect. Crazing is when a ceramic glaze starts to crack due to tension. The pattern is a bit different than something like an egg shell cracking, so photos were helpful. This example in particular is what I based my pattern on.
I started by drawing a pattern on one side of the teapot. I focused on one side at a time so that I wouldn't smudge the pencil lines. The following photo shows my pencil drawing (it looks carved, but that is just an artifact of the graphite reflecting light).
Following the pencil drawing, I added areas that will be carved, and/or routed, away. For this side I added these after the fact, but for the other sides I laid them out prior to drawing the pattern. After the drawing was complete, I started burning the pattern with a woodburner on medium heat and a sharp skew tip. You can see in the photo that I first burn the longest, most continuous lines, and then move on to the "filler" lines. Side note: it takes a lot of extra time to draw the pattern prior to burning, but it gives me the best chance to create the most realistic pattern (as well as revise/fix as needed). Once the line is burned, there's not much you can do.
Here is a shot of the entire side completed. Note, the other side is visible in the previous post where I discuss spout placement.
After burning both sides, I did the same thing (draw and burn) to the bottom of the teapot. I also left a space for my name, year, and title. I decided to name this tea pot "Ban Wa Renaissance" which alludes to 1) taking a traditional ceramic form and recreating it in wood, 2) the intention of the embellishment as shedding the old to reveal the new, and 3) the excitement (and benefits) you get when trying something new.
Stay tuned for the next steps!
Love this contrast in tone. Pleasant surprise for anyone who decides to look underneath.
Thanks Jaramiah! I fear you’ll be disappointed though, as much of the surface is going to dyed/painted. Won’t even be able to tell that these are different woods (also why I wasn’t worried about using different wood for the handle/spout). Sorry buddy! 😂
I made some solid progress on the tea pot yesterday and this morning. I finished up all of the pyrography on the body, lid, and the lid handle.
The lid handle was a bit tricky, as clearance underneath was minimal. So, it was a lot of back and forth to make sure I was lining everything up correctly. It is also a bit challenging to burn straight-ish lines on such a small curved surface, especially when the pyro skew tip is close to your fingers. Slow and careful wins the race. The following is a shot of the handle attached to the lid (but not glued yet). You can also see why I went through the trouble of adding dowels--in addition to the strength/security they provide when the handle is glued, they allow me to maintain registration as I continuously remove and re-insert. Takes out the guesswork.
Following the pyrography, I began adding my black base coat (India ink). Before I added the India ink, I took some time to relax the edges a bit with 600g sandpaper. I still wanted to keep everything crisp, but lightly sanding off the edge helps the India ink and future paint stick ore permanently. If the edge was sharp, the ink/paint comes off easily and you'll be left with odd bare spots. I also lightly sanded the glue seams down the middle of the body and on the bottom where the floor panel meets the rest of the body. When burning the lines, the glue tends to bubble up slightly. Sanding the seams helps to mask the appearance of separate pieces. Following sanding, I went over the entire surface of the teapot with a red scotchbrite pad. This helps to smooth out the pyroed surface, as well as remove any overburn reside (wood oils and CA glue) that might interfere with the color (and/or be ugly and obvious in the end). Given the goal is to sort of mimic a ceramic surface, I want everything to be as smooth as possible. Here is a shot of the teapot with a coat of India ink applied:
Obviously, there are bare spots left. I did not apply any ink where I will be gluing the other components (spout and handles). I also did not apply ink to the surface where I will be routing/carving away. Eventually, I will go over this surface with a fine scotchbrite pad and add another layer of India ink to smooth it out. Then, I'll add color. There are a few more steps before I can start adding color though. Here is a sneak peek of the teapot with the spout and handles temporarily in place.
It's starting to come together! The next step is to route/carve away the bare spots to "reveal" the wood. Then, I will finish refining, pyro, attach, and blend the junctions of the spout and large handle. Then, I'll add India ink to the spout and handle, go over the entire surface with a fine scotchbrite pad, add another layer of India ink, and then start adding color. Then I'll apply the finish, and then I'll be done. Can you see the light? :)
It's one of those projects where you look back and say "Wow how did I do all that to get to this point"!! But it was all worth it!
Alright, when I said that cutting the teapot apart was the last stressful procedure...that was a lie. Routing out the recess was the last stressful part that remained. Stressful in the sense that something disastrous could go wrong. Fortunately, no major issues occurred, but there were a couple of minor things that need/needed fixing, as well as a fun problem-solving situation. I first used a palm router and 1/8" spiral downcut bit to remove material from the areas I had indicated before (in the photos above, some of the non-inked areas). You can see in the following photo my clamping setup. I tend to use the ways of my lathe for a lot of things, and I suspect I'm not alone. Partly because a lot of other surfaces are covered in junk...lol. I clamped a board to the ways, and then clamped my teapot body to the board with protective paper towels between surfaces. I routed 3/32" deep, an arbitrary depth that looked good to me.
One of the minor issue was that as I got close to the edge on one of my areas, the router base wasn't in a huge amount of surface contact with the teapot and I accidentally dropped an edge. This resulted in routing a slight divot:
In the photo above, it looks much worse than it was. Shadow lines... To fix, I increased the depth a hair, and re-routed the surface. When I got close to the edge, I stopped, and then finished stock removal with a sharp chisel. You can see the result in the following photo. I also routed away material from the top curve (next post), and that fixed 90% of the issue. Once sanding is complete, all will be well.
Routing the flats was relatively simple, but routing the curved body required some problem-solving. Initially, I was planning to carve away the material, via drilling reference holes at a specific depth and then carving. However, given the surface is largely endgrain, I didn't want to run the risk of burning the wood (it will be visible in the end). Also, sanding didn't seem appealing. So, instead of carving, I came up with a way to use my router. Routing a curved surface with a flat-base router, especially a convex surface is unreliable at best, and sketch at worst. I decided to make a temporary base that matched the profile of my teapot. I started by cutting a small piece of wood, and then I used the same procedure as I did for shaping the mating surface of the spout and handles: I started with a spindle sander to rough the contour, and then refined the curve by using the teapot body (cutoff) as a sanding block. I also used a support piece to ensure I was holding the piece of wood at 90 degrees to the spindle sander. After the curve was made, I marked the center on the flat side, and used my drill press and a 1-1/2" Forstner bit to drill a hole that was slight larger than my router's clearance hole. I then lightly sanded the curved surface to 400g, and applied some paste wax to make the surface low friction.
To attach the curved block to my router base, I used the ole reliable blue tape and CA glue trick. I first applied some painter's tape to the base of my router and the flat surface of my curved block. To the router's tape I added a bead of CA glue (I used medium CA, but thick works just as well).
To the block's tape I sprayed some activator. Then, I brought the two surfaces together--bam, instant solid and temporary router base that matches the curve of my teapot body.
This was a much better solution than carving. It was a bit of work on the front end, but paid dividends with clean cuts and perfect contours. Here is a shot of the top of the teapot showing the lid. I did this in two sections, and used tape to secure the lid in place. You can also see that there is a tiny hole that I need to fix. This is the hole that I drilled to accept the pin. Unfortunately, given the depth I drilled previously, this was an unavoidable issue. I'll fix it well enough, but it will probably be slightly visible in the end. Not perfect, but that's okay.
I used a similar clamping setup as above, but added an extra block so that I could clamp the teapot horizontally instead of vertically. Here is a shot of the setup.
The next step is to sand the recesses. Then I'll work on finishing and attaching the spout and handles. Onward!
Updates coming soon--I'm fighting the deadline, so I've been more focused on the making and less focused on the posting. But, I've been taking plenty of photos.....stay tuned!
I didn't take photos of sanding the recesses, because...well...no one wants to see those. I started mainly at 220 (180 for a couple of the curves recesses) and sanded to 320 with the grain. Where there was endgrain I sanded to 400. Pretty basic. The next step was to attach the spout. I had previously refined the shape and added the 1/8" dowels to the, so now it was just a matter of attaching. Prior to attaching, I cut short sections of dowels and filled in the extra holes (attached via some thick CA). This wasn't totally necessary, but it would ensure that much of my glue couldn't escape into the holes.
You can see in the photo above that I also rough sanded the surface a bit to help with adhesion, as well as drilled a hole so the spout-hole continues into the body. Of course, this teapot won't actually be used for tea, but I still want the features to exist as if it was totally functional. To glue the spout, I made a mixture of 5-minute epoxy and fine sawdust. I mixed the epoxy first, and then added enough sawdust to make a "loose peanut butter" consistency. This means that I would still hae a lot of strength, the expoxy would be somewhat carvable and solid, and the glue could flow freely to fill any gaps. I put the glue on the surface of the teapot (avoiding the through-hole as much as possible--though, I did have to drill this out later anyway), a bit in the dowel holes, as well as the spout. Once the spout and body were mated, I used a good amount of pressure to seat the spout and reate a bead around the border. The bead told me I had a continues glued surface. I probably used a bit too much glue, but that's better than using too little.
I then wiped off the excess glue and used an elastic hair tie as a clamp. FYI, epoxy does not need the same amount of pressure as something like PVA glue (titebond), so the hair tie was perfect.
Once the epoxy was set (I let it sit overnight to be safe), I did some preliminary sanding. This was mainly to remove excess glue from the surface, but also to check the contours.
Following some more sanding, as well as some light carving with rotary burrs, there were a couple of minor fixes needed to help with the transition between spout and body (i.e. make it smoother), so i added a small bead of thick CA around the border.
I let this cure for a few hours, and then sanded again. I also used some fine diamond burrs and rifflers to help smooth the transition.
It turned out alright. Not quite perfect, but I was 99% happy. Following the photo above, I sanded the spout fairly smooth (only to 220g), and then with a pencil marked the lines to be burnt. Similar to before, I used a fine skew tip to burn my texture lines. I also re-burned the lines that got too shallow from sanding and/or got filled with epoxy/CA glue.
Burning into the spout was a bit of a steady-hand challenge, but not too bad. I made sure to burn lines as far back as possible. Once the burning was done, I went over the surface with a scotchbrite pad, and the covered the spout in a layer of India ink.
To enhance the effect of the exterior eroding away to reveal wood, I need to continue the burn lines through the walls of the recess. The problem is that I had to burn close to bare wood without overburning and making spots. To help prevent overburn, I added some oil to the bare wood to serve as a bit of a buffer. This was also nice because I got a preview of the grain.
I then use my woodburning skew tip to burn lines onto the recess walls.
Following this, I burned lines at the junction of the wood and the recess walls. Originally I used a pyro shading tip as it is angled. However, the tip was too bulky, so I switched back to my sharp skew tip (I bent the tip a bit to give me a good approach angle). I then carefully excised the lines. This complete the texture effect. I ended up with a couple of overburn spots, but was able to carefully sand away most of the char. A bit remained in the end, but it's not that noticeable (unless you know what to look for).
In addition to enhancing the texture effect, incising a line between surfaces helps with appllying paint/ink precisely. The burned line creates a border/sink and helps to prevent getting ink on the adjacent surface. I was able to use a fine paintbrush to apply India ink to the walls of the recess.
For the lid handle, I need to be a bit more careful because I there's not much clearance to work. Fortunately, the surfaces of the handle and the lid were matched well to minimize gaps. Additionally, I didn't need to worry about a smooth transition here (like with the spout and main handly). I first dry fit the handle to the lid and then used tape to protect the lid surface from squeeze out.
I then used thick CA glue to attach the handle to the lid. I had previously drilled holes in the lid and handle, and added dowels to the handle for support. I also took the time to draw/burn my lines before attaching (again, there's no clearance to work so I had to finish this before attaching). Once the handle was on the lid, I removed the tape. Easy peasy.
You can see above a very minor gap between the handle and lid. No worries here--it was so small that a little bit extra India ink and future paint filled it nicely. A couple of the photos in the previous post show the lid once it was coated in India ink. Then it was time to attach the main handle to the body. I first masked off the body like with the handle, and rough sanded to help with adhesion.
As before, I made a mixture of epoxy and sawdust, applied some to the holes/dowels and body/handle mating surfaces, pressed firmly together, and used a piece of painter's tape to clamp the pieces together. Somehow the hair tie went missing (classic), but the tape clamp worked fine. Once the handle was in place and clamped, I wiped away the excess epoxy/sawdust mixture, being sure to leave a smooth transition between the two handle and body.
Once the epoxy had set for a couple of hours, I removed the tape.
I let the epoxy cure overnight before do anything else. To refine the handle transition, I first lightly carve away the excess epoxy and any bumps in the wood with some diamond burrs.
I then sanded the transition until it was pretty smooth. I sanded mainly via small pieces of folded sandpaper, but also with some sand paper wrapped around a small dowel.
Looking back, there were a couple of spots I could have sanded a bit more cleanly, but I'm mostly pleased. I then started laying out the lines with a pencil and then burned the lines. I did this in sections to make it easier to work around the handle. Burning the underside was a bit of a challenge, so I worked slowly and carefully (and bending pyro skew tip helped a bit with clearance). Here was the first section of lines I burned:
You can see I focused on the transition areas first, but also burned a few long lines from one end to the other. Working in sections also helped to keep the pattern somewhat random. Here is the next progress pic:
After some more of the same, I eventually finished burning the lines into the handle. In the following photo, you can probably see that I also smoothed the surface with a scotchbrite pad:
This was a massive milestone, as all of the pyro was done. Whew!!! Following this I coated the handle in India ink, and then went over the entire surface (sans recessed areas) with another coat of ink. Here are a couple of shots after the ink dried:
Then it was time for the fun, relatively low stress part of the project--paint! (though I did have a couple of d'oh! moments...you'll see). I started by adding a light undercoat layer of prism violet acrylic gouache via light dry brushing. Acrylic gouache is a paint that I have been gravitating toward more and more lately. It has the deep pigment and very opaque qualities of gouache (a type of heavy watercolor paint) combine with acrylic binders that help it dry fairly quickly and stably. The color palette is a bit more limited than basic acrylics, but that's not an issue when you can mix different colors.
My plan was to paint the surface so that it has a Western raku potter vibe (raku is a Japanese ceramic firing technique, and the "Western" is a modified version that can produce vibrant, metallic colors (see this image for an example). Here is a shot of the teapot with the first coat of paint applied. Inevitably (as per usual), this is the point where I thought "ugh, I should've just left it black". BUT, trust the plan move on, and try not to think about how bad and blotchy the first several layers look.
Originally. I thought I might be able to get away with not covering the recessed areas. That wouldn't really work though, as I would end up with a dark, interrupted border between the recessed areas and the rest of the paint. So, I decided to mask the wooden areas before I continued painting. I bought some thin low-tack Scotch tape (this is the source of one of my d'oh! moments), and taped it onto some thin paper. I then pressed the paper onto the recess and used a pencil to transfer a drawing of each of recess' perimeter. To do this, lightly rub the pencil around the perimeter--the edges of the recess contact the paper with more pressure, and thus more graphite is removed.
After the tracing was complete. I used a pair of scissors to cut out the shape. Voila, a perfect-ish patch to protect the wood while painting.
I then removed the tape from the paper, and placed it onto the wooden surface.
Once all of the recess were taped/protected, I added a few more layers of the same prism violet paint. You can see how the surface becomes much more uniformly colored. The multiple thin layers helps unsure that there are minimal brush strokes and fairly even coverage.
The surface doesn't have to be perfect, otherwise I'd use an airbrush. Some variation in color density is fine, as this is just the beginning. The next step is to start adding more colors in certain areas. I used some fairly transparent quinacridone blue violet acrylic paint and some opaque quinacridone magenta acrylic gouache to create gradients in a few sections of the teapot.
The transparent acrylic doesn't cover as nicely as the opaque acrylic gouache, but it can be used to nicely smooth transitions between colors. Here is a shot after several coats of paint (I don't have photos after every single coat...no one would want to follow along there LOL).
I then mixed a couple of colors to darken and tint some other areas of the teapot. Like I said before, the acrylic gouache is nice in that it can be mixed with other acrylics to create whatever color is needed. In the following photo you can see the result (on the plate) of mixing the prism violet acrylic gouache with some opaque indigo acrylic. I did this because it creates a better base color (hue and value) than either color could individually (for these areas I am going to apply some "blue" colors).
Exceeded my expectations it’s wonderful! First I took a quick look at the pictures and I thought of shou sugi ban technic (maybe because I’m repairing an old chair and decided to turn it black ).
Greetings
Here is a shot after a few layers of the mixture from above. The difference between this and the previous teapot shot is somewhat subtle, but you can see a much deeper gradient (value contrast) between certain areas.
For a top color (top at this point), I used another acrylic gouache, turquoise deep.
After a few coats, I ended up with the following.
The key here is subtlety. When dry brushing, especially on a relatively flat surface like the teapot, you want as little paint on the brush as possible. I typicaly use a paper plate as my pallet. No real reason other than convenience (they're cheap disposable). I usually put a bit of paint on the plate, dab my brush into it and move it around the plate a bit to remove paint (and create a uniform filling on the brush). Then, I rub the brush on a paper towel to remove as much paint as possible. When I'm moving over the painted surface, I use fast, light, whispy strokes. This keeps the visible strokes and splotchiness to a minimum. The downside is that it requires many layers. Fortunately, because you're using so little paint, there is fairly little down/drying time between coats.
Time for more color! For some parts of the teapot, I want to add green and yellow color variations. I started with some fairly dark sap green permanent and some bronze yellow, laying down individual layers of each, as well as a couple layers of these mixed together.
