Finishing up a 16 x 12-3/4 x 5/1/4 (once tenon is removed). Applied first coat of walnut oil and missed a couple of burnish marks😡, should have wiped it down with some DA and I would have seen them before the oil was applied. So I’ll wait t week and sand those two marks out.
You guys have mentioned applying DO, what exactly is DO?
DO - Danish Oil - a type of varnish finish sorta like Formby's (Now Miniwax) Tung Oil, I believe... Contrary to popular believe it is not made from squeezing Danes... :)
Okay 😂, I use a lot of Danish Oil but was racking my brain trying to figure out what DO was😂
Our snow is finally melted, still barely above freezing but good enough to make a few pictures of recently finished turnings, did little turning as it is just too cold to enjoy turning.
This is a Black Walnut piece (vessel/box) that I choose to show off this very figured White Birch piece I turned into a lid, it shows the changing chatoyance constantly when rotating it it.
The perfect burl I showed the other day was finished last night.
Australian Yellow Box burl...
(Still wet from DO) Has extreme undercut rim.
Can't decide how I feel about this root ball burl. I've been driving by it sitting on the side of the road for at least 6 months. The hidden pockets of dirt and rocks did a number on my chainsaw and tools.
A Historic Foundation ask me if I could turn a bowl from a piece of a white oak they cut down beside a church they are preserving. I of course said yes and I wouldn’t charge them anything. Well I did the second turning today on the two bowls and had a piece I was able to turn a plate….an offering plate …you know…just in case 😂😂
Very nice turnings from that Oak wood David, is it dry already ? , if not, be careful drying it,😍.
A few years ago I started turning this piece of Cherry burl and after I got started a ways ants started flying out of it. I sprayed it with raid or something and set it aside. I have looked at it and couldn't decide if it was worth trying to turn. A couple of days ago I decided to give it a go. When I got the inside to shape it had quite a big void that I thought needed filling to have a base. I used a little ground turquoise and epoxy. Some spots are a little soft so I put a coat of DO before I finish sand it. Still not sure how I'll finish the foot, but at least now there will be something to finish.
Nice Leo! Funny side note, when I see pieces finished with PTO, I always think of finished with Power Take Off for a tractor 😁
My first thought was "finished by the Parent-Teacher Organization... ?" :) Took me a little while to get used to thinking "Polymerized Tung Oil"
I'm working on cleaning up the shop, some bowls aren't making the cut for finishing. So they are providing some warmth and entertainment in the burn pile. I may post this picture by the lathe as a warning to other rough outs as to what their fate may be if they don't behave.
Here is another one that I have had almost finished for a least a year, I think it is elm. It has a small crack on one of the sides that I wasn't sure about. But I really like the feather pattern so I decided to finish it. It has been turned once and I left a bit on the base to carve feet. The base warped a bit so as you can see in the first picture that I will need to level the feet. It is finished with DO and is still wet in these pictures.
Got this far on the third of the series of sycamore sculpture pieces (before a half hour drive south to meet a transporter for the regional bird rescue & rehab. Got to climb a pine and place this young Great Horned Owl back where its parents could guide it along. Left a 1/2 dozen mice and two rats hung around the tree for him. He’s what is termed a ‘brancher’ - developed enough to hop from branch to branch.)
Turning Etimoe disks to go at the two focal points.
Then I’ll turn away the back half, leaving just a few circular ribs to hold the pieces in place.
Finish turning a swamp Kauri bowl. Will be 9.5”d x ~3.5”h when complete. A turner sent me a blank from New Zealand and challenged me to mimic a smaller bowl he made. Fun! This is quite a challenging timber to turn. It is extremely soft, very stringy, and dulls tools quickly. The reward is fairly intense chatoyancy and a rich color.
Finish turning a swamp Kauri bowl. Will be 9.5”d x ~3.5”h when complete. A turner sent me a blank from New Zealand and challenged me to mimic a smaller bowl he made. Fun! This is quite a challenging timber to turn. It is extremely soft, quite stringy, and dulls tools quickly. The reward is fairly intense chatoyancy and a rich color.
Wondered where you’d been! Nice work.
First time working with Sassafras. Unfortunately, my blocks were bone dry so I didn’t get to experience the apparently wonderful smell when green-turned. Still, it turns nicely and sands well. Here is a piece after some preliminary sanding at 150.
whenever I work with sassafras my shop smells like an A&W root beer stand!
