Turning between centers
Royal Oak, MI
Good suggestion, but how's he going to convey the aroma of turning bone? It's an essential part of the experience and one you'll not soon forget!
Yes, it smells like the Dentist office . ;-p Scraping the bone, there is not much smell. its sanding that puts it air born, and breathing can be hard.
C.A.G.
I found that the old dry bones turned with sharp tools so as to get less heat would make the smell a lot less, it is as with horse shoeing where the hot iron would make the most smell when fitting the iron.
Here is another turning with bone, top and bottom finial are from an old dried beef bone.
Red Oak, VA
Ponsford, MN
Wow, very precise work. They look identical.
Thanks but if you look very closely you should be able to detect some differences then again if mounted in a balustrade it is almost impossible to detect the differences. VA likely has some historical mansions open for viewing built at a time when each baluster was turned individually so if you were to tour one you could look close at the stair case and likely detect slight differences.
Red Oak, VA
But that would spoil the magic :-D
