There you go Robert. In about a year I could have it done.
There you go Robert. In about a year I could have it do e.![]()
How about a modified duplicator? Driven by two syncros controled by an Adreno. You can monitor the control: feed rate, rpm, travel speed, current draw on the liner axis (tool drag), thermister on the tool for temp., an endiscope attached to the tool holder for video.
Then you have imperical data to crunch. If you synk the video camera' audio trak with the rpm input to the Adrion to create a click track you would a visual record too. = total data.
To me the hard part is making the tool tip holder.
a special cut I hone and polish. That edge is gone in moments. But did what I needed. It makes a sizzle sound. and like in Alans article the cut is smooth on smooth. But not worth my time unless needed.
I don't drink but I'm thinking about starting now. Since the edge retention test is an after thought of my original test which was simply to find out if the different steels could be sharpened to the same level Done that The edge test needs to something g I can do and get it over with so I can get back to turning. I think I can turn the ball bats by using peeling cuts to get down to size and the. Planing cuts to finalize the shape. If I can't tell when it gets dull with any certainty I'll just turn the same number with each tool. The. Look at the photographs and hopefully see some difference
John,
One more thought. You might make a reference mark on the top of each tool to use for the planning cuts.
If you are like me you shift the tool cut to a sharp edge without thinking about it.
I think for this experiment you want to cut in the same place on the tool.
There is one variable that can be important: The distance of the edge from the original edge, i.e. how much have been already ground. A tool is hardened by heating and cooling but this process is influenced by the thickness of the steel and the distance from the surface. There is a gradient in the heating/cooling process that proceeds from the surface to the center of the steel. Thus there is a variation of the final hardness in the same tool and between tools.
Besides every sharpener has his/her touch and what is the result of one person often cannot be reproduced by another. What really counts, in my opinion, is the starting grit of the sandpaper: non need for sanding = good tool. But...one moment, when there is no need for sandpaper? I feel there will be the need for another test...
That would depend on the type of tool, the manufacturer, and the heat treating process. For most tools, the cutting edge is on the surface. The skew is an exception. Some manufacturers use induction heating for tempering and only harden and temper the first couple inches or so. Others treat the entire tool for a long period of time, so the "gradient" would be essentially nonexistent. In any case, I believe that the metal is heated to the Curie point which is easy to detect and assures that the steel has all been sufficiently heated.
Just as a guess, I would say that John isn't interested in this becoming a masters thesis project.
Force feedback is the parameter that would be needed. All of the others are irrelevant to the control system, but might be of general interest to somebody. Unfortunately, force feedback is sort of the Achilles heel of feedback control system design. No matter how force is instrumented, it is a very noisy signal with bias offsets and quadrature components which means, in addition to other things, heavy filtering which translates to out of phase response and marginal stability at best. My experience with force feedback in the control loop is that it is a disaster looking for a place to happen. There have been many attempts using sophisticated adaptive Kalman filtering and whatnot with just as dismal results.
The tool tip holder would be child's play in comparison.
I am nor familiar with Adreno or Adrion.
