- Joined
- Jan 27, 2005
- Messages
- 13,220
- Likes
- 5,850
- Location
- Dalworthington Gardens, TX
- Website
- pbase.com
..... I've been thinking about putting the chisel in my metal lathe. advance the cut a known amount into the work as it rotates and then use the power feel to go from one end of a turning to the other. maybe make 2 or 3 passes with each tool and then look at the edges....
I've been toying with using MDF or particle board simply because it might be more abrasive and at the same time more consistent. I'll have to look around and see what's available locally. I sharpened the chisels so far up to 1500 grit and then touched them on a leather strop to finalize the edge. That's as sharp as I get my hand plane blades and they cut wispers off wood. When I took slices off a piece of paper I couldn't believe how easily it cut. Probably not as easy as the floating silk in the movie Bodyguard (which myth busters proved wouldn't work anyway).
From an engineering perspective, my opinion is that while you are working hard to eliminate variables that would otherwise cloud the data, I am more concerned that the test methods that you envision appear to have diverged too far from real world conditions. Before proceeding into the test methods, I would suggest first clearly defining the fundamental objective. After that, variables can be more easily identified and, to the extent possible, determine if there are methods that can be used to mitigate their effects. Otherwise, I see a risk of making the test results not very meaningful.
I understand the rationale behind the idea of normalizing the way that the cutter is used in the test, but don't believe that the power feed on the metal lathe is the right approach. There is a fundamental difference between metal machining and wood turning in the way that the cutter is used. In metal machining, the power feed is a position control system whereas woodturning is primarily a man-in-the-loop force feedback system (or to state it more simply, it is anything other than a position control system).
Particle board and MDF are the next best thing to an aluminum oxide grinding wheel to my way of thinking. They both consist of a high percentage of very hard and abrasive bonding material (urea formaldehyde resin, in the case of MDF). The fact that they contain cellulose seems not especially relevant because, other than that, it doesn't have much else in common with cutting solid wood. It looks like the test would be mainly scraping an abrasive material rather than making a true cut that slices through real wood. If you're looking at gauging edge longevity, I think that scraping an edge against MDF isn't the right approach.
For all of its ambiguities, it is hard to beat cutting real wood in the traditional manner as a measure of how well an edge holds up. There is no question of when the tool quits slicing wood and there is no need to look at a photomicrograph to verify that.
I'm sure that you have turned MDF and particle board, so you are very familiar how nasty it is. Besides making a thorough mess of your shop with all of the dust that it creates, it is really bad for your lungs. If I must turn it, I will only do so outdoors with a breeze from my back and wearing my Airstream respirator. I would rather turn a banksia pod ... and I hate turning banksia pods.
