- Joined
- Dec 22, 2006
- Messages
- 7,123
- Likes
- 9,889
In a recent discussion, the desirability of, and trend for manufacturers to offer more increasingly powerful motors has led me to some casual thinking on the side.......(Uh, oh.......here comes trouble! Ha!)
First, I must say that I have never had more than 1 1/2hp to work with, so my input here is strictly theoretical on my part.........
It seems to me there are only two main reasons why more horsepower is desireable........the most important consideration it seems, would be that it allows turners to take massive cuts in a single pass, and the other will be related to the size/weight of the block of wood mounted.
Nobody could deny that horsepower is needed for both applications, but I am questioning whether massive cuts is desireable......except for the obvious!
I'm sure everyone here has experienced hot shavings on their hands. The act of cutting wood, and bevels rubbing creates heat, right? The heavier the cut, the more heat created. OK, so how many of you understand that the heat you create is drying the wood quickly, if only on the surface?
Drying wood too quickly is the most common cause of cracking in wood. Let's just say that a very tiny hairline crack, one you may not, or cannot notice at the time, and even though it is, at this point, only on the surface.......could become a major crack later on during the seasoning process. It just may be that sometimes, some of us have no idea we are actually initiating cracks that will only be realized later on.....when it's too late!.......
Even though I have less power than some turners, I have noticed some surface cracking on my turnings during the roughing stage. These tiny cracks may only be visible momentarily, and then close up when the surface cools. (I have seen this phenomenon with my own eyes!) I wonder if I've caused cracks that I never did realize were there, until later on.......?
Generally, even though I process lots of very wet bowls, I'm not very much plagued by cracking, and I think my drying techniques are contributing to that.....but, once in awhile, I do get them. I just have to consider all the possibilities, and surface heat in the roughing stage is one to consider. Even though I only have 1 1/2hp on tap, I can take some pretty big bites......and create a lot of heat.....but obviously not to the extent that someone else who has a more powerful motor can make.
Sooooooo........if any of the above is credible, and true........then it could be reasonable to suspect some of us are causing our own cracking problems without realizing why. It could also be true that, unless we are putting monster blocks of wood on our lathes, then the craving for horsepower and taking massive cuts, isn't something that is ultimately desireable........
It cannot be questioned that market sales determines the evolution of lathes, and I can see where the manufacturers are simply responding to the demands of those buying their products.......and, those buying lathes are overwhelmingly inexperienced turners. Maybe I've been on the right track all along by not having more power available to me........because it forces me to make more passes with less aggressive cuts! :cool2:
If I drive my SS396 Chevelle at the same speed as everyone else does, I won't get those tickets......but, man is it ever impressive to have all that raw power! I only get into trouble when I actually use it! Heh,heh,heh........!
