Ashley did an excellent job of teaching and is obviously a good turner. I enjoyed her demos. I ran the video camera and she is much easier to keep up with than Stuart and knows how to work with the camera that made my job easier.
I've been playing with the 40/40 grind for several years. It's ok. I dont think it's the cats meow. It does cut cleaner than my Thompson v gouge but then it is ground at 50 degrees or so. A more blunt angle will not cut as clean as a more acute angle, however it let's me cut the entire bowl without having to change to a bottom feeder gouge. I also prefer longer wings on the grind because I use pull cuts and shear scraping cuts with my gouge. If I want a really clean cut I use my Hunter Osprey or Hercules in a push cut and it cuts as clean as my 40/40 gouge and you dont need to sharpen it. If I really need a clean cut I use my Spindle gouge which is ground to 35 degrees but of course it won't let you turn all parts of the bowl. Just my opinion of course but it's based on a lot of turning.
