Photo of your workstation
I think I posted shop pictures about a year ago, but it's always fun walking out into my shop so I just snapped some more. The first couple are the turning area where I spend about half of my time, the last two are my 5x7 finish room and the dust collector space sandwiched behind it, and the remaining in between are a panoramic view of the shop if you can stitch them together in your minds eye. More than you want...
edit: not sure what I did but they didn't order as intended, but I'm sure you can figure it out :)
Ron, I see you have built an extension on your Sawstop. Mine has an extension added on by Sawstop, but it is too large and cumbersome. I have a small shop so portability is important and your extension table appears to be an easy up and down, as needed. Could you provide me with any plans you used for this?
Alan Jurgens - my shop is also small so everything is on wheels and gets moved around when I’m working on big projects. My SawStop is on their hydraulic mobility frame (I really like it) and also rests on 4x4s to get the table height more comfortable for me. I built the off-feed table to integrate into the hydraulic lift system so everything raises and moves together, but it doesn’t fold down. I really like the fact the support legs go back to the saw instead of down for sweeping (lots of lathe shavings go into this area).
I could envision easy ways to make something similar that would collapse but you’d have to attach it to the rails differently than I did just using c-clamps.
@odie I like the handles you’ve added to the bowl calipers. Great idea. Looks like it makes them much easier to use.
Also like the 5 drawer chest
It's much better that way when you can use it one handed! When I bought the Versa-cal calipers next to it, I had to do the modification!
Odie- I love the caliper modification! Any chance you could post a picture of the calipers straight on with a ruler in the shot so I could duplicate your proportions?
Hello Will.....You are the 2nd person to enquire about those modified calipers.
I did the modification about 10-15 years ago, and used miscellaneous stuff in the junk box to do it. It does work pretty well, though. I used some rubber tubing to give it some "grip", which seems to help with usability.
I missed that mod earlier, thanks for posting the pics. That is a slick idea. I may try making some out of wood that curve inward, not needing the handle you added. Did you try wood and have a problem with it?
Steve Nix, is that the variable speed PM drill press? I just picked mine up and am waiting for daughter's boyfriend to come over and help me get the top part on. Do you like it? I thought it looked like a better fit for me than the Nova DVR one, which has too many 'programmed' settings, which for me is more than one....
Wood would probably work fine, Doug.
I didn't try wood....just went with what was available at the time...
Here's my work area for turning. The jointer in the pic doesn't normally sit there. The multi drawer unit holds all my sand paper and sanding mandrels and backer pads in 2" and 3" from 80 grit to 800 grit. I use a raised platform in order to make my height compatble with the spindle center line. I set this up so that everything that I need to turn, sand and prep for finishing is within arms reach. I do have to turn around to get my turning tools out of the wheeled tool rack.
View attachment 41372View attachment 41373
Your pictures are very helpful Odie! Thanks. My calipers are similar size so I am going to put this on my to-do list! Will
How about a photo of your main turning workstation? It's nice to see what folks came up with for storage, accessibility.
Oneway 1640 lathe and 14" Rikon bandsaw hooked up to a Laguna B-Flux dust collector
Ron, if you want your pictures to appear in a specific order after uploading them from your computer you need to first put the text editor cursor where you want the picture to appear in your post. Next, click on the attached picture that you want to insert and click on the word "Insert" in the upper left corner of the picture, and then click on either "Thumbnail" or "Full Image". Repeat this process for each picture to get them in the desired order.
WOW! That is the cleanest shop I have EVER seen!! Its...so...sparkly!
There is almost something....unnatural...about a woodshop without any wood dust or shavings in it... :D
Doesn't look like that today!
Here's the disaster at my place. We moved three months ago and it's not organized. I just need it to work right now.
The other views of my shop- it doesn’t show the extent of the windows, but the light is at the sacrifice of wall space!
Am I seeing an airplane in there?
Nice shop, though! You guys have really clean shops...
Well, it's not really that clean.
The airplane is a plans built Acro Sport II, Lycoming O-360 with full inverted systems. It's basically ready for cover and paint. Unfortunately I've played with too many hobbies and have probably aged out of aviation.
Yeah, I wish that I had room for a dedicated wood shop. My turning space has to share the garage with a motorcycle, multiple bicycles, the lawn tractor, and another work bench for the mechanical/oily stuff.
So here's a couple of pics of my turning corner. I obviously need a better solution for my gouges, as they're kinda stacked on top of each other right now. I don't want to do too much fixing up as we'll likely be moving next spring.
I actually know what that is; I used to be an EAA member. In fact homebuilding and flying my own airplane was my first plan for a retirement hobby. Until I realized that I wouldn't be able to move any plane parts I built out of my basement shop. So I took some flying lessons instead and discovered I don't have the temperament to be a pilot. Two years later I found out I had heart disease, so I would never have filled the log book, anyway. I guess it worked out. I think this hobby probably costs less anyway.
might as well add mine! taken AFTER a spring shop cleaning
How did I miss the airplane????? Too busy looking at the shop. Never got into powered flight, but flew a hang glider for about 10 years. Most fun I ever had. "Any one can fly the dang things. The taking off and landing is the difficult part." My Dad was in the first graduating class at KU in their aeronautical engineering program. He worked in Washington DC for what ever it was that became NASA. Quit that to start his own business with his dad. I have found anything that flies very interesting.....
I saw the part where Robo mentions the Nova DVR drill press (Nova Viking DVR) and I chuckled as once I got this there is no way I could live without it. I won't go into it but it is awesome!
Those blister buttons would be a turn off for me, but having a variable speed controller for the drill press would be great! Question: Does running at slow speeds lose torque? It would seem that's exactly when it would be needed the most......ie: Drilling holes in steel at slow speeds.
Note: My 30 year old Delta has to change belts for speed changes, but the torque is a constant.
I love the airplane in the shop! I went to high school with John Travolta. We were in a flying club run by an art teacher who was a pilot. We both got our private tickets before finishing high school. I flew through college and a bit beyond, until I got married and money had to go in a different direction. Now he’s got a 707, among other things. I’ve got a Powermatic!
20211125_074607.jpgwould this router speed control from H F work $18.
I have the Voyager and the DVR upgrade on my 1624 lathe. One of the advantages of the DVR motor is that it maintains torque at slower speeds and as far as I can tell in actual use it does. But torque without momentum is not the same thing, so it is still easier to stall either motor at slow speed. That's just my un-scientific observation/explanation.
The blister/membrane buttons are not my favorite type of actuator (even on a microwave) but I have found that there are different versions out there. The Voyager buttons actually work fine, and I have also tried the buttons on Saturn and Galaxi display models and these seem to be made differently and also work fine. For the DVR motor on my lathe I solved the problem with adhesive "bump stops" applied to the on and off buttons. I have tried several types of bump stops and the ones that work best are the small foam rubber circles. I am happy with my solution, so I would not dissuade someone from purchasing the products based on the buttons alone. Also, it's worth mentioning that the Voyager has a well placed emergency stop button that you can easily hit, even with your forehead.
As to the myriad of programable features, there are a few I use all the time and other features I never use.
