G0698 18" X 47" Wood Lathe
Another positive opinion
Hi all,
I happened to be looking at some other forums, and noticed a thread about the Grizzly G0698, and there was a guy who bought one, got it home and had a friend who has a 3520b come over to see it, and the 3520b owner was very impressed with the machine, and could not hardly believe that much lathe for the price.
The 3520b owner was impressed with the power, smooth performance and the quality of the lathe. So far, I have to totally agree. I believe this is a very good lathe for the money, and has features that match up with most other machines that cost twice as much or more.
There are versions of drives - not on lathes - that are single phase output which are being used less and less on equipment. They are more expensive and problematic than the 3 phase output versions. In searches that I have done, I can only find one company and it is in England that actually make the single phase output VFD drive any more.
Actually, single phase drives are still in wide use, but for very specialized applications. Their primary application is for systems that have essentially zero starting torque and where load torque is constant and proportional to motor speed. A common example of this type of application would be air handlers in an HVAC system. Also, pumps with zero starting load torque would be another example. These motors have low power output. It will not work with the typical capacitor start induction motor. Typically the motor would be a shaded pole induction motor. The cost of a single phase drive would be lower than a three phase drive, but the trade-off is that three phase motors are cheaper than single phase motors. With the cost of drives coming down, I can see the cost factor tipping in favor of using a three phase motor and drive in new installations.
related to the shop fox 1758
what about the shop fox lathe 16x43= w1758 2 differnt guys have them new on ebay shipped for 600.00 or less! anyboy know about these? its a great buy. thanks; daniel
I too took some interest in the shop fox w1758, but once I got to looking real close then I did not like what I saw. The slowest speed is 600 rpm, and that is too fast for large bowl blanks, especially one that is out of balance. It is too light in weight, and I did not want to chase it all over my shop.
It also has the articulating tool rest which is a weak system [in my opinion] and I like a slower speed for sanding operations than 600 rpm. I am really glad I waited to get the grizzly G0698, because so far, it has met all the expectations I had hoped it would be when I decided to buy it.
I had looked for 4 months a Laguna's 18x47 before I found out Grizzly was going to carry the same lathe. I was also interested in the Powermatic 3520b, but found the cost somewhat prohibitive at the current time. As of now, I am VERY happy with the G0698.
still happy
Hi all,
After having my Grizzly G0698 for 2 weeks, and turning several projects, I really like the performance and features of this lathe. It is smooth, quiet, and has the power and torque to get the job done in short order. I am turning faster, and sanding less than with my old Craftsman lathe.
I mentioned that I would give some on-going reviews as I was able to turn because the lathe is new to the market, and there seems to be considerable interest among a number of turners for this lathe because it might be the difference between having to settle for a small lathe, when they could have a large capacity one in their price range.
Good luck to all, and I will review further in a few weeks.
Roger,
Is there anything the least bit negative that you have found so far. I have every intention of getting one of these when I get back home in April. The only thing I have heard so far as a fault is the stripping out of the tool rest hold down lever which appears to be an easy fix. My only problem with this lathe is the size but I think I can make it fit.
No negatives, one wish
Roger,
Hi Paul,
I have not found anything negative so far about this lathe. It is powerful, smooth, full of features, and in my opinion a large step above what some of the earlier and lower end models that Grizzly used to carry.
That being said, I do have one wish, that would have in my opinion have made this lathe even better. It is something though that can easily be addressed by the owner with no problems. The nut on the screw shaft that holds down the tool rest and tail stock are simple large sized hex nuts. The manual plainly says to "periodically adjust the nut for fine tuning the lockdown lever" but My wish is that they would have put "lock nuts" with nylon inserts because that would have locked in the adjustment for long periods of time.
It is no big deal though, because to adjust the tension, you just reach underneath and hand tighten the nut, just a hair. Simple, but the optimal would have been the lock nuts. I have placed a lock washer under mine because that's just my preference. It is not necessary in either case, and I guess to make this lathe as affordable as it is, they had to be as basic as possible to cut down costs.
I will say this though, the pulleys, wiring and switches all look to be first rate to me, and I am a happy camper so far. I believe that this lathe stacks up very well with the Jet 16/42 evs, and has more capacity, and for the money it sure gives the PM 3520b a serious run for features and quality [my opinion, of course]
As far as the size, I was concerned as well, but I don't think it takes up much more space than a Jet 16/42.
Best of luck Paul!
Roger,
Hi Paul,
As far as the size, I was concerned as well, but I don't think it takes up much more space than a Jet 16/42. The manual says that the space you will need is 81 inches by 23-1/2 inches, and that is for the headstock being in the farthest left position. It is a good idea to have the stated amount of room in which to place the lathe, as it is good operating space.
Best of luck Paul!
Roger,
I am really happy you found the Grizzly to your complete satisfaction and I am certain you will have great fun turning to your hearts content!
With every discussion of Grizzly, the issue of price and value is the predominant factor. So too it seems with this discussion and your particular decision. Not all of us have won the lottery and can afford a $3000 lathe.
I have purchased two Grizzly lathes, one wood and one metal. I currently own a Jet 1642VS 2hp.
I looked at your photos posted on page 3 and offer the following commentary on them.
1631 The machine has an obvious legacy to the PM and Jet line. As John Lucas mentioned, the weight difference is no doubt because the iron castings are smaller and thinner than the PM/Jet versions.
1632 and 1642 The motor appears to be constructed of some sort of extruded case. I’ve never seen a large 3 phase motor case like this and would be interested in how it is constructed.
1633 Nice close-up of the headstock. The blend-lines, fillets and hard edges of the casting hint to a somewhat lower grade foundry work compared to the PM and Jet components. It’s OK, but not the same quality or execution. The screws and hardware appear to be more or less the same “Grizzly” grade stuff that has been my experience. You might someday end up replacing those with ISO/metric grade 8.8 or better.
1634 & 1635 The adjustable handle levers are relatively low grade material and will eventually need to be replaced. On my old Grizzly I found some German-made replacements – which are so nice I did the same on my Jet.
1636 The revolving center looks like the one that comes on their 1232 lathe. Does it not look a bit small for a lathe that swings 18 inches? Similar sized machines from Jet and PM come with centers with triple-row bearings. Also the bolts that anchor the bed to the legs look pretty small.
1637 I am surprised to how see the spindle does not extend beyond the rear of the headstock. As mentioned you get along fine with it this way.
1638 & 1640 The wire tool basket looks like a truncated version of the JET. Probably just there so they can say they have a basket “like the Jet or PM.” It’s a basket.
1639 Yep! You purchased one of the first 10 of this style lathe ever made!
1641 1642 1643 no comments
1644 1645 The tailstock ram appears to have the graduation markings stamped whereas on the Jet and PM these marks are laser marking... laser marking keeps the ram perfectly smooth and is more accurate – not that it matters but it is a nicer way to do it.
1646 1647 no comments
All in all, you did get a lot for your money. This was introduced at $300 less than their 16/42 lathe so it is reasonable to expect the price will go up later. This is definitely a “get it while it’s hot” deal. Although I personally would not buy another Grizzly lathe, I don’t begrudge those who do. Happy turnings!
Not a Cadillac, but ....
Hi Bob,
Thanks for your response. I have been busy digging out from this blizzard here in N. Va. and came in and saw your posting.
When I purchased this lathe, I was under no illusion that it was a "Cadillac" lathe like the Oneway, or the PM 3520b. I kind of feel like this analogy is true.... You can get to your destination in fine style with a top of the line luxury model like a Cadillac, but if you need to get somewhere, then probably a good "Buick" will take you to the very same destination. It might not be quite as luxurious, but the ride is pretty good none-the-less.
I find that perhaps the pictures don't do justice to the handles on the tool rest and tail stock. I can tell you, they are substantial. The ways are a thick casting of 5/8 inch. I have turned on a 3520b of a friend who is in our local club, and some other lathes as well, and I am a person who is a stickler for performance and quality. I agonized [somewhat] over which lathe to buy. I started to limit myself to the 3520b, but decided I wanted more distance between centers, because I turn furniture parts sometimes, like table legs and bed posts, and the 3520b needed a bed extension accessory which retails for $459.00.
As far as the live center goes, I knew that I already have others that are heavy duty, and this one seems just fine to me, and for the price I did not expect to receive all things I could possibly want in the way of accessories for this price.
I do not consider myself the definative voice in all things woodturning or woodworking, but I do have over 20 years experience at woodworking and probably a little over 8 at turning. Other turners needs and projects may require a more substantial machine, and their preferences have been developed over time with what works for them.
My considerations for this particular machine were that I wanted value, quality, capacity, features like the variable speed, reversing, 3 phase and good customer service in the event I needed parts or service in the future. For me and my particular interests, and likely projects, I think I have struck the right balance for my needs and my budget, and I think this lathe stacks up beside the Jet 1642 evs, and features are similar to the 3520b.
I think you are probably right when you say "get them while you can" because it is my understanding that Grizzly will raise the price when the new 2011 cataloge come out.
It is really nice to be able to have other folks interact around our common interest of woodturning. Thanks for your reply, and I enjoyed your post...
Blessings!
casting of the lathe bed
Hi all,
I wanted to clarify something related to the casting on the bed of the lathe. The thickness of the ways are 5/8 inch and the bed has heavy webbing and support of the bed itself.
Just trying to give accurate info...
No horse in this race
For the record, I don’t have a horse in this race. I’ve owned, for 5 years, a General Intl. 25-600 with a Reeves drive (which will never have electronic problems!) and never turn really large, or really wet, or really out of balance stock. However, I do appreciate the need for low speeds and massive lathes – if that is what you are turning. I don’t own a single piece of Grizzly equipment, however as a life long woodworker (>55 years) I have watched Grizzly since their inception some 25 years ago. I have been amazed at the value for the $ that they are able to provide. I think that the GO698 is just such an example. It appears to be quite useable at an attractive price – not a novel concept in the Grizzly world. As woodworkers, we tend to love equipment. The latest, bestest, mostest will surely improve our work…. When I see the GO698, I don’t think about what it doesn’t have versus lathes that cost 1.5 to nearly 3 times as much. I think about things like, what should a 3520B really cost? What are you paying for really nice engineering and what are you paying because of the Powermatic image? I would bet that all lathe makers, today, have low cost, off shore sourcing. Remember that a Chevy, a Buick, a Cadillac, a Mercedes, and a Rolls Royce will all take you from NYC to LA, safely.
Jerry
my sentiments exactly
Jerry
Jerry,
You make my point very well. Every woodturner has his/her own needs, interests in certain types of projects, methods of working and their own techniques as far as tool usage. I think it is a STUPID thing to have a "pissing contest" to satisfy egos, or for anyone to make assertions as to what "the Best" is, although I will say that there are certain manufactures that have exemplary track records with their machines.
The "best machine" is the one that gives the turner the greatest opportunity to reach their potential, and serves their work methods the best for them.
I don't claim to have the "best machine, " however I believe the Grizzly G0698 will serve me well, and it served my budget well also.
Thanks for your post!
I have a few Grizzly items. They have cheap tools and higher quality tools. My table saw I would put up against ones costing twice as much. My belt/disk sander is usable but not top notch. I knew that when I bought it and did not want to spend the extra money at the time for a better one. My jointer has served me well and my dust collector has been great. I think Grizzly is very capable of a quality machine but each one has to be evaluated on its own. Thats why a review such as this one by a owner is so great in helping with the process. Thank You Roger for your efforts.
my motivation for posting
Hi Paul,
Thank you for your post. I don't want anyone to misunderstand the reason I posted concerning this machine.
Here is my motivation: knowing that this lathe was new to the market, and knowing that there was a lot of interest among many who wanted a larger lathe, but maybe were not in a position to part with over $3000.00 in this economic downturn, and knowing that there was a good bit of uncertainty, as some lower end Grizzly lathes had a less than desirable reputation, I wanted to give what my honest views were as a new owner.
I had done all the research I could, and given the choices I had, I took what I believe was a well thought out decision, which now having gotten the lathe, used it a bit, and having seen its performance up close and personal, then I felt that my experience might help others who wanted to give this a try, but were not sure.
To the extent that this has helped someone else, I am glad for that. If my posts have informed as to my own opinions and observations, then it must be remembered by all that they are indeed "my observations and opinion" and must be considered in the light of each persons needs and interests, and at least if they are helpful to someone, then that is a good thing.
I hope no one has perceived my postings a a "gloat" because I'm not into that, nor do I want anyone to have a misperception that I feel that I am an "expert" in the field of woodturning. there are many more experienced, gifted and innovative persons out there than I, and I look to them to gain inspiration for advancing in my skill levels and understanding of turning wood.
I wish all who are out there the best, and send my highest regards...
Thanks for the update
Roger,
Many thanks for your review and please keep us updated. Have been interested in this machine ever since laguna came out with their brand and now seriously considering the grizzly 18x47.
Thanks,
Ned
Roger,
There is a thread on another forum from a guy that is having problems with his G0698. It appears that after he gets below 130 rpm the lathe is not smooth. In his words the spindle pulses (herky/jerky). He also says the tail stock is sloppy and not machined to very tight tolerances. I am posting a link to his thread but I tried to do this on their forum and it got deleted so I am not sure it will work here.
http://www.sawmillcreek.org/showthread.php?t=132398
Just wanted your coments on his complaints. Grizzly is telling him that is the way the slow speed works but it seems like that is their first line of defense to try and get the customer to accept the problem instead of fixing it. I have heard the from other people.
Grizzly's Tech support - Looking into the issue
Roger,
Paul,
I contacted Grizzly tech support this morning about this issue, and referred them to a previous conversation with a tech support representative, and told them of the concerns that the other gentleman, and I have experienced with this "pulsing" at very low rpm. They are going to send this matter up the chain of command to the Washington headquarters, and trace it to the factory if necessary.
The rep. I spoke with today told me it may take a week or so [maybe two] to get this addressed, but that they would contact me. I asked them t look into the inverter, if it was the problem, or need for reprogramming it, or the potentiometer not being sensitive enough, or what the issue might be, and I informed them as to the negative press they are getting on another forum.
The response I got today was one of genuine concern and assurance they would look into this and get back to me. We will see how they address our concerns and what actions they take to remedy the problem. For now we are in a time that we must give them fair time to research and address the issue, and will wait till they respond.
Roger,
Thanks for the response. I communicated your actions to the person on the other forum. I guess then you too have experienced this erratic low speed operation. I have never used a lathe that would go below 400 rpm so I would probably be thrilled to get close to 100 rpm but if they advertise it should work then it should work.
Hope you get a good answer.
I own a Laguna 18/47
I've owned the Laguna 18/47 since August 2009 and am very happy with it. I've turned everything from pens to a 25" bowl (I have the outboard turning accessory).
I got their newer version with the handwheel on the spindle. That handwheel threads on to the spindle shaft, then is set with two set screws. The threaded spindle shaft and flat area on the shaft for the set screws are out past the cover plate on the end of the headstock. Looking at your pictures I don't see how you could use the Laguna handwheel. Let me know if you'd like me to take a couple pictures of the Laguna handwheel for your reference.
I run at 10rpm or so to sand and apply finish and I have not had any herky-jerky operation. My guess is that it's an adjustment on the inverter board.
I have been able to stall mine though, while turning a 15" green Hard Maple bowl I was taking more than a 1/2" cut with my Easy Wood tool and it stalled. You just turn it off then on and it's ready to go. I've also experienced what I'll call a "Safety Stall", I was turning using the outboard turning accessory and was turning a 25" piece of dry white ash and had a HUGE catch with a big bowl gouge, on/off with the lathe and it was ready to go. Me on the other hand needed to figure out that catch before moving on. :eek:
Pics of hand wheel, etc.
Tom,
I would very much like to have pics from you to show how your handwheel connects to the spindle. I appreciate your offer. If the cover plate on mine is removed one can see a flange that has a threaded hole on either side of the spindle.
I hope that you are correct that the "pulsing" we have at low rpms is simply a matter of making an adjustment on the inverter board. I don't know how to do those things, but maybe tech support at Grizzly will walk me through the process when they get it figured out.
Thanks for posting your experience with the Laguna 18/47 and letting us know that the problem seems to be with Grizzly's version. We await Grizzly's information and remedy.
laguna 18/47 Hand Wheel Pictures
Hello Roger,
I took a couple of pictures of the hand wheel on my Laguna 18/47 both on the spindle and off the spindle so you can see how it goes together. I've attached them.
I wonder if Laguna changed the spindle in order to add the hand wheel? With it sticking out of the rear of the headstock cover on mine and flush with the cover on yours I think the spindles may be different. It would be a job (and cost) to change the spindle just for a hand wheel.
Do you have a picture of the spindle with the cover open?
Tom
Is it possible that there is an adapter attached to the end of the headstock shaft to extend it out through the side.
Hand Wheel Pics
Hello Roger,
Tom
Hi Tom,
Thanks for the pics! I sent you a return email with some further info on my set up. A little closer look inside your cover might show a flange with a spindle extension. Let me know what you find! Great photography!
New info from Grizzly tech support -pulsing at low rpm
Hello everyone,
I heard back from Grizzly tech support on the "pulsing at very low rpm" issue that I and another owner have reported to them. The engineers have said that they got the specs wrong, even in the catalog and online.
They say that the Low rpm specs should be 100 rpm, on the low belt setting, and the high belt setting low rpm spec should be 330 rpm.
I pressed the tech guy as to why some owners of the Laguna model report no problems with their version, and the reply was that they cannot speak to the machines of other companies, but that this lathe was made to their specs. I then said that even the labeling on the lathe itself is wrong; they said "correct." Even when I asked about the inverter being reprogrammed, the engineers say that is not the problem, it is simply their specs to which the machine is built.
For me, in the grand scheme of things, this "pulsing at very low rpm" is a mostly minor annoyance, and not a true hindrance to achieving good turning success. Most of my years of experience of turning have taught me that it is very rare to need anything below 100 rpm, and sanding and finishing on my previous lathe was limited to a minimum of 400 rpm, as that was the minimum speed for that lathe.
Most machines [except Oneway and Robust] are manufactured in China, and I have noticed as of late that there are owners of Jet and Powermatic that are speaking of problems with their machines, so I guess that it is a "try to do the best you can" deal. The other problems are being discussed on "another forum" [runout on a Jet(spindle, bearing issues) and shimming tailstock to align with headstock on a 3520b]
Grizzly has a return policy, and said they would pay the shipping back to them, but as of now that is not what I want to do. Again, I see this as a very minor annoyance rather than a problem that hinders me in turning projects, as I would most likely have very rare use for less than 100 rpm.
My bottom line - for me personally, is that I still believe that I have a good machine with good features for a good value. That was what I was looking for when I made my decision to purchase, and what I want for the future is longevity, performance and availability of parts and service in the future if it is needed.
I hope that my perspective helps any out there that may be considering the purchase of a new lathe, and had this one in mind to look at.:rolleyes:
Laguna 18/47 Spindle Pictures
Hello Roger,
I've taken a couple more pictures of the spindle with the hand wheel and cover plate removed and attached them to this post.
The spindle on my Laguna looks to be one piece, you can see in the picture where the groove is cut for the pulley key, that's where two pieces would have to join if there where to be two pieces.
I've included a picture of the end of the lathe put back together to show how I mounted a pipe with a 1/2" ID using the cover plate screws, I put a swivel light fixture in it. I pretty much have light everywhere I need it while turning.
Tom
Similar set up
Hello Roger,
Tom
Tom,
Thanks for the additional pics. Your set up is similar to mine, and the only difference that I can see in the pictures is that the spindle on yours is longer. that being said, I wonder if your spindle is longer all the way through to your other side where the chuck is mounted, or if it is a 2 piece that is threaded onto the flange with the threaded holes on either side of the spindle.
I can't tell from the pics if the spindle is threaded on the inside of the center to accept an extension, or if it is a single, longer spindle assembly on the Laguna than is on the Grizzly version.
I guess Laguna will have to clear this up for me, but your efforts are greatly appreciated, and they do show similarities. I guess I will know later. One question though, did you try to see if the part that the hand wheel screws onto was itself able to be un-threaded off the black flange?
Thanks again Tom, you've been a great help!
Roger,
Could you take a picture of yours with the cover off? I am assuming the black ring that the keyway is in is where the two threaded holes are on yours that was mentioned a while back.
Paul, you are correct
Roger,
Hi Paul,
the black ring [flange] has two threaded holes, one on each side of the spindle, and in Tom's picture, the spindle is rotated so that only one of them is showing.
Do you have the G0698? Are you planning on getting a hand wheel accessory?:rolleyes:
As far a pics go, I would have to get my son to help me with that and I don't know how soon that would be. My computer skills are minimal at best.
Now that I take a second look at Tom's pictures, I notice that there is a set screw on top of the flange, and I am wondering if the spindle on his has two parts, the one which connects to the handwheel having a keyway, and locks in place with the set screw? If that is indeed the case, then I could easily adapt that to my Grizzly G0698....
laguna Spindle
Hi Roger - The Laguna spindle is one solid piece from one end to the other, neither end screws off. It shows it that way in the Laguna manual and by looking down the hollow spindle it looks that way too.
The black flange in the picture is the pully. The threaded hole on the face of it is commonly used to screw bolts in to use to push it off of something. The other threaded hole above the key is a set screw for the two stepped pully.
Tom
Tom
Thanks Tom,
That clears this issue up. Maybe in the future, Grizzly will find a solution to help their owners, as did Laguna. Best of luck!:)
Roger,
I don't have a G0698 as of yet and it might be a while if what I read is true that they are backlogged till June. Just trying to understand what I am getting into. I am not real happy with Grizzly's answer to the speed question. As you said 100 rpm is probably fine for me but it really looks like it was suppose to go to 0 and because it does not they are back pedaling. I think the lathe is a screaming deal for what it does do but I hate this kind of support. I have heard stories like this from some Jet customers also so what do you do.
I was wondering if you could make an extension out of wood to bolt to the black flange out beyond the headstock and then make a wooden hand wheel to mount to that. It does not have to take a lot of stress therefore it should hold up as long as it is balanced. Just a thought.
Paul
Wooden hand wheel -
Roger,
Paul
Hi Paul,
I think your idea of a turned hand wheel bolted onto the pulley [flange] would be a workable idea. Thanks!
Grizzly's tech support has been upfront with me, but in this case I think that they could work at bringing their inverter up to what the originally advertised specs were. It seems to me, that they put out a machine, and basically have said "this is what it is, live with it," however I believe that especially since other versions like the Laguna 18/47 have owners who report this "pulsing at very low rpm" is not an issue with their versions; that Grizzly could make the effort and find out a solution, if they would contact the factory, or be willing to make adjustments necessary to bring the specs in line with what was advertised originally.
They have since talking with me changed the specs to the new ones I referenced on and earlier post. I think it is the tail waging the dog, and perhaps they believe that this is the simplest fix, but I tell you, they are loosing reputation, and frustrating customers.
In my case, they have hurt themselves, as I have future plans for building a new shop, and I am going to need additional tools. I was interested in a large planner, and some other machines, but now I am having second thoughts.
I do believe that I have a good lathe for the money, but this problem, albeit, a minor one, I believe is one that is able to have a remedy, if they would only "man up" and do what it takes.
Our only options should not be to either return the lathe, or live with it!
HEY GRIZZLY, ARE YOU LISTENING????
I noticed this problem is found below 100 rpm & because I am interested in this lathe I printed out the manual, on page 25 they recommend a speed of 190 rpm for roughing out a 16" bowl if your having trouble below 100 rpm maybe this is the answer. I don't have the answer to this but thought this recommendation interesting. This leaves you with 90 rpm leeway before you hit 100 rpm. So you could still drop the rpm 35-40 rpm & still be at 150 rpm for a 18" bowl It looks like they are recommending a increasing roughing speed variable as the diameter decreases.
Grizzly's recomendations not the issue
Hi Bart,
The issue is one of what the lathe was advertised to do, not what they recommend as far as turning speeds. The website and the catalog [pg. 126]had the specs at 0-1200rpm on the low belt setting, and 0-3200 rpm on the high belt setting. The labels on the machine and in the manual say the same thing.
The lathe "pulses" at very low rpm, and instead of doing what Grizzly has done, and that is go back to the website and change the specs on their page about this lathe, they simply changed the specs to reflect what the tech guys told myself and another owner.
That leaves us with a choice of 2 options, either return the lathe, or live with it. They could have done what I believe is the correct thing, and worked at getting the inverter, or whatever else might be the cause, [including the fact they said they got the specs wrong,] and make this thing run smooth at low rpm.
This is mostly an annoyance, because most turners don't get below 100 rpm very often, but some do, and to know that the machine is not operating as it was advertised is a matter that should be fixed. Grizzly needs to "man up" and address this issue, other than just wash their hands by a return of the lathe from those who like me put a new electrical service in my shop just to accomodate the 220 volt this lathe runs off of.
Grizzly is loosing reputation, and customer trust [imho]. In the realm of the possible, we know that other versions of this lathe, carried by other vendors are not having these issues, according to owners that are posting. So we know that this is fixable, if Grizzly would just do what it takes. The fix might be a new inverter, or reprogramming or something else, but it is a do-able fix.
I still feel like this is a good machine, with a minor issue, but it should be fixed by Grizzly.
In my humble opinion, if the spindle turns, it should not pulse. Grizzly changing their spec does not solve the problem, it ignores it. If they say 100 rpm is the minimum speed, that's the speed at which it should first start turning, not a pulsing 50-something rpm. And from what I've read, it seems there have been reports of pulsing at slightly higher than 100 rpm, too.
I know you'll get lots of good turning with that lathe as it is, and you don't expect the super-low end speed to be critical, but I do hope that Grizzly finds a real solution and makes it available to the owners. They're a good company, so I suspect they're not really ignoring the problem, just buying time until they get a handle on it.
Hello Vaughn,
I sure hope that you are right about them "buying time until they get a handle on it," because it was my understanding that they were a good company as well, and were very good at resolving customer issues.
I want to keep this lathe, but I want it to do what they advertised and what it is labeled for and that is 0-1200/3200 rpm. Other versions like the Laguna 18x47 is the same lathe and owners who post said theirs do not have this problem, so in the realm of possibility, there is a fix out there if they would just "man up" and do what it takes.
I just want the lathe to be what it was advertised to be, and I had to change out the electrical panel box and run new circuits in my shop to be able to power the lathe, so I made a big investment on their advertised specs and this looks to me like something that is a fixable issue.
Lathe
I notice on all this everyone keeps saying it is the same lathe as the Lugana. Has someone looked to see for sure that the inverter is the same on both lathes. My guess is the lower cost lathe used a cheaper inverter and that is what is causing the problem. Many times they use off the shelf parts, so they have no idea how they are designed to work, they just know if they set it up this way it works in their application. They have no idea what other configurations might work too.
If they are not the same then I would say to order an inverter and motor for the Lugana and install that on your lathe then it would be the same. Now your lathe will run closer to the one you are comparing it to.
This is where a lot of us get ourselves in trouble. It looks like something else so it must be as good. Not always true. If it is cheaper, then something is probably different, we just don't let ourselves see it.
changing horses[specs] in mid-stream
Rick,
Grizzly does have their own specs. The lathe carries the same labels as far as the rpm belt settings as do all the other lathes like this one such as busy bee, Hare & Forbes and Laguna. If Grizzly is going to use the same specs on their labels for the machine, and in the owners manual and on their website and catalog,[until they changed them, after the fact] then they should bring the performance in line with what they advertised; which is what customers like me were counting on.
Because this issue, according to the ones who posted, who own Busy Bee and Laguna models of this same lathe report that theirs do not have this issue, then we know that this is a fixable problem. Grizzly most likely could bring a fix about, if they were willing to do what it takes, as other vendors have the same version of the lathe and do not have these issues.
In all of this I was reading & a humorous thought popped into my head I remembered Ray Stevens song about the Shriners Bubba your fez is the only one with a propeller on top........& it pulses.:eek::):D
Busy Bee states speed at Variable Speeds - Low Range: 0-1200 RPM
High Range: 0-3200 RPM.
Do we know for a fact their their lathe actually does operate this way?????
Laguna states speed at Variable Speeds - · Low: 60 - 1200 rpm
· High: 200- 3200 rpm
Grizzly ....Speed range high: 330-3200 RPM low: 100-1200 RPM.
They used to state on line low 0-1200 & high RPM 0-3200 the paper catalog & owners manual state the same. It appears to me that Grizzly either knew what it should be & actually made a printing mistake or someone went out & put it through its paces several times & found out this is the way it actually works.
Then they went & changed the on line specs to match what they should have been or what they just found out.
I really want to purchase one of these lathes later this year but this leaves me with some questions in my mind???????????? In fact I am saving up to pay cash, so I really wonder?????
Rick,
Good point, and we probably don't.
One thing to remember (and this is a result of a discussion I had with the owner of Grizzly)
Just because a tool "looks" identical, doesn't mean it is. Yes, it is possible that a Busy Bee, a Grizzly and a XXX may all be made in the same factory. But they may be made to different specs.
They also may not even be made in the same factory. In that area of the world, it is very common for a lot of similar appearing tools to be made, to widely different specs.
Another point, Busy Bee is NOT Grizzly, yes they appear to be similar, but they may not be. The two firms are owned by brothers, the brother that owns Grizzly has, IMO been more successful then the brother that owns Busy Bee. They also have an agreement, not to see across the border, period. Although quite a number of people in BC, make the short drive to Bellingham to buy at Grizzly
TTFN
Ralph
