- Joined
- Dec 22, 2006
- Messages
- 7,140
- Likes
- 9,993
Hi Odie
Actually I don’t think the opposite. I don’t believe one has an advantage over the other. You will have some “play” with either. To me when you pivot or slide the head there is that chance. When I slide my headstock to the end the tailstock is out of the way same as a pivot. When I return my headstock or when the pivot is returned seems to me you can have similar results using the tailstock as they slide similar. No difference in my mind. I don’t buy a sliding headstock has more chance for problems. I don’t think either better than the other and both are acceptable. As with anything it depends on the quality of the mfg.
OK, thanks for the reply, William......
