WTB/WTT: Stuart Batty Grinding Platform Mounting Plate
Status
Not open for further replies.
WI
Looking for the mounting plate (part the platform mounts to and inserts into mounting base). I have a Oneway base adapter if you have a Wolverine system you'd like to use your platform with - even swap.
I'd also buy just your mounting plate if you already have the Oneway adapter.
Wouldn't have a problem buying an entire platform assembly either (2" wheel cutout preferred)
**What I have is on the left, what I need is on the right**
Australia
I have the part bolts onto the platform (not the mounting base though) which you can have for free as I use mine in a Wolverine system but the shipping from Australia might make it too expensive. If you can't find something closer to you let me know.
Cheers
Josh
Status
