Woodcraft Slow Speed Grinder UPDATE - Hot is NOT OK
HOT is NOT ok. I've returned the grinder to my local Woodcraft. The owner and a couple employees all agree that the grinder should not run. Owner will contact Woodcraft HQ about this issue. Looks like a bad batch of grinders.
This is an update to the earlier thread regarding Woodcraft's slow speed grinder getting very hot.
Today, I took my hot running grinder to Woodcraft for an exchange. There were two more at the store, both of which were tested and these ran hot after about 15 minutes. So that is three!
The gentleman at the store called Woodcraft HQ technical department and discussed the hot running grinders. Tech support acknowledged receiving complaints form other Woodcraft stores so they took a dozen grinders out of the warehouse and ran them for a protracted period of time. In every case they ultimately got very hot and their conclusion is that this is normal.
It appears this is inherent in the current crop of grinders offered by Woodcraft. Ergo, hot running is apparently OK and unless it burns up, I'll keep it .
I took the grinder home and returned it to operation. Doug
