wood veneer auto dash parts
Hello all,
I am applying a lacewood veneer over the existing surfaces of the dash and glove box of my classic car. There is about 7 pieces in all. I am wondering what you guys would use to finish this surface for a convertible car. My thoughts would be to use oil based poly for its hardness in this environment.
I will not stain it as the gloss over this wood with the little ambering of poly will be beautiful. Since I have noticed that lacewood is not a perfectly smooth wood, can I build up more coats of poly to get to a smooth surface?
Can some of you get me on the right track? Am I heading in the right direction?
Thanks
GPope
Tampa, FL
As my finishing friends in another forum are fond of pointing out - poly's main advantage is abrasion resistance, which makes it great for floors, and not much else. I would go with an alkyd resin varnish like Behlin's Rockhard, or, if you want to wipe it on, Waterlox. I have built a really nice, smooth finish with 8 to 10 coats of Waterlox Original.
I was looking at Minwax Helmsman Spar Urethane. On the label it says it has UV protectors, good for water and moisture and great for temperature changes. Is that a good brand or does someone else make a better product? It is for exterior use and looks like it might fit the build.
In a convertible, sun will definitely be a factor.
Thanks
Tallahassee FL
Spar varnish is used on sailboat spars, hence the name, so it's definitely suitable for outdoor exposure. It usually needs a sanding and re-coat every year or two. I used Minwax's Helmsman Spar Urethane on this outdoor sculpture: http://mysite.verizon.net/vze8eg0u/kwameweb/
After about three years, it could benefit from refinishing, but the sanding is daunting to say the least. Much easier for flat or round work.
Joe (Kwame = born on Saturday; no African heritage that I know of)
Donna Banfield
Derry, NH
That's a really cool mailbox
but in these parts (NH), that sculpture is a magnet for bored teenagers, some alcohol and a baseball bat.
Very few mailboxes are left alone. :^(
Joe,
Since the dash will be in a protested area (auto), will the spar varnish need that much upkeep? It not like its going to be in the outdoor environment constantly, if at all. I would say that sun and temperature change (hot summer to cold winter) as the only realistic environmental challenges.
Dick, I looked up Rockhard and Waterlox, both fine products. Would I be in trouble with the UV and temperature change.
I also need something that wil not need regular maintenance.
Thanks
Pope
Sonoma, CA
I had a house built a few years back. We have wood doors. I talked to a number of pro painters and they said that the outside doors should be finished with a spar varnish - due to the UV protection it provided. The outside doors are protected by a porch pretty much and in 6 years have not needed to be re-finished. Some of the doors do get morning sun and others get the afternoon sun for a couple of hours. But they seem to be fine. For inside doors I was told to use polyurethane. Both are oil based and applied about the same - look the same, etc. I think I would go with the spar varnish. Krylon has a spray can UV protection that can be put on before putting on another finish. I have not had enough use to tell you any results though.
Hugh
Wouldn't you need to find a finish that doesn't yellow with time? It has been my experience that varnish starts to yellow in a short period even Helmsman. From the gulf coast of Texas,
Gentleben
