Dick, are you asking about wiring the power supply to the VFD, or the VFD to the motor, or the VFD to the lathe, or all three?
The first suggestion may not be possible--take a photograph of the prior wiring before you disconnect.
Second suggestion, there are several good references for Powermatic 3520's--maybe it's the same on yours, or at least similar enough for that info to be helpful. Here are 2 good ones:
https://www.aawforum.org/community/threads/powermatic-3520b-vfd-replacement.14784/
https://www.docgreenwoodturner.com/pmcontrol3.html
Third suggestion, connecting the power supply to the VFD is fairly straightforward and the manual for the VFD will tell you how. Similarly, wiring the VFD to the motor is fairly straightforward--you just have to follow how the previous VFD did it (if you still can). I tried to attach a copy of a Delta VFD manual, but it was too large a file. It's probably not exactly the one you want, but you can get it from the Delta web site (note, it's NOT Delta woodworking tools)
Wiring the VFD to the lathe controls is trickier, and depends on how many wires you have running between the two. Generally 3 or 4, plus 2 going to the speed readout. If the attached materials don't answer your questions, maybe check what color wires you have connected to headstock control locations and post that info. Someone with a 2020 could then look at their VFD and see which wire is connected to which terminal.
