Richard Baker
RIP
Just tried some wire burning (correct technical term?) suggested by a friend (you know who you are) in conjunction with another process. Could not find the old hacksaw with the broken handle to hold the wire, so had to twist it around a couple of dowels about a foot apart. Started slowly to try keeping tiny wire (0.029") in tiny groove. Finally successful burning at about 1150 rpm on 7" diameter.
So the question is what rpm do you use at what diameter? Granted that it depends upon the kind of wood, maybe the kind of wire, and amount of pressure applied. But should be a "ballpark" number that will do the job quickly and reliably.
Looking for "surface velocity" at the contact area. On my test piece the surface travel per revolution is Pi x D, or 3.1416 x 7" = 22" per revolution. At 1150 rpm that is 22 x 1150 = 25,290 inches per minute, or 2,107 ft. per minute.
Does this seem about right, or maybe way too slow?
