  • Congratulations to David Croxton for "Geri's Basket Illusion" being selected as Turning of the Week for February 2, 2026 (click here for details)
Why do lathe spindles use coarse threads?
The only problems I've seen with lathe spindles is being bent, or the threads not matching a particular chuck or faceplate. The later is probably a tolerance thing since every screw and nut has a tolerance and if you happen to get a spindle on the plus side and chuck on the negative side then problems arise.
The bent spindle seems to be more common. I have not seen it yet on 1 1/4, m33 or 1 1/2 but have seen it several times on 1" spindles. Usually from putting too large a piece of wood on a lathe.
The minor diameter of a 1-8 spindle is 7/8", the MT2 is 3/4" at its widest, so the wall thickness on a 1-8 is 1/16" at its thinnest, with a metallic cross section of 0.184 in^2.
The minor diameter of a 1 1/4-8 spindle is 1 1/8", so the wall thickness on a 1 1/4-8 is 3/16" at its thinnest, with a metallic cross section of 0.625 in^2.
Thus, a 1 1/4-8 is around 3x stronger than a 1-8, while a 1 1/2-8 would be around 6x stronger than a 1-8. The better bearings of the larger lathe probably also helps.
