Looking to get a largers set of jaws for my 5.5" vicmarc to do larger bowls/projects. Craftsupply has three types:
Standard dovetail
multi purpose
step jaws
My thoughts:
The step jaw does not appear to have as large of dovetails for holding and the step is only good for compression. In compression mount the smaller the diameter, the longer the tenon would have to be and it seems the jaws would interfere with the work.
The multi purpose seems to have the similar issues. in the larger compression mount the tenon would have to be hollow to allow clearance for the smaller jaw. When using the smaller part in expansion mount you would be limited in tenon thickness by the larger jaw.
Seems the standard 5.5" jaw is the best choice. Standard chuck comes with 2.5" jaw and i have the pin jaw already. With these three jaws, I should cover any range I need. The only advantage to the multi purpose and the step jaws is the convenience of not having to change jaws a lot. Seems the negatives of the jaws outweigh the positives.
Am I missing something? Anyone have these that can offer his or her thoughts?
Standard dovetail
multi purpose
step jaws
My thoughts:
