A question for users of the Vector grinding jig (Hannes Tools). Have you ever used the jig on a spindle gouge? If so, how did that work out? How did you set it up?
I don’t disagree that the leg angle does affect the grind, but the operator has a lot of control. Wing length is controlled by the amount of side swing of the jig and amount of material, ie grind time, spent in an area. I use a different jig (tormek svd-186, provides a very similar grind), and can grind sg’s at the same “leg angle” as a swept back grind, but get a sg finger nail grind."the jig that comes with the vector has a fixed angle."
Yes, that's the issue. One can mount a spindle gouge onto the Vector, but the fixed leg angle is more acute than would be desirable for a spindle gouge and will create longer wings.
