signatureturner said:
In the Spring 2004 issue of American Woodturner, Nick Cook mentions use of "urethane oil" to finish his pepper mills. Can someone tell me what urethane oil is? Is it a friction finish or does it need to be applied in some other manner?
Thanks,
Larry
While I haven't torn the "Urethane Oil" that he sells, apart yet to see what is actually in there, I suspect he's just talking about an oil-based polyurethane. I don't know if he (or more likely has someone else) makes this himself or is just re-branding another companies product either.
I'm going to wildly guess that the product might just be a thinned varnish like Waterlox, Mark VI, Formby's Tung Oil, etc. That doesn't mean it couldn't be called a "Urethane" because the varnish base could be a polyurethane resin ... which has a urethane backbone in it. But, as I said, this is all a guess without tearing it apart chemically. Maybe it's just some mixture of a polyurethane or varnish with added oils to it. Unless the product actually gives the FULL LIST of ingredients (and we all know that wood finishes always correctly give you the truth.... ha!), you just don't know until you do some analysis on it.
An actual "Urethane" product can be anything from a water-based polyurethane finish to the foam in your pillow or the spandex on some aerobics instructors' rear-end.
"Urethane" is like saying I use a "Car". You have no idea why kind, size, type, or model of car I use but you do know that it's not a "Truck". There are all kinds of "Urethane" finishes ... from acrylic-urethanes to water-based to oil-based and on up through modified forms of oil-based ones that include the polyurethane glues.
It's not a shellac-based friction polish like the Mylands High-build or the Hut Crystal Coat (among many others) nor is it a lacquer-based friction polish. So, my guess at this point is just an oil-based polyurethane. Wipe it on ... wait a few minutes but not long enough to let it get gummy ... wipe off what's not been soaked in. Repeat as desired to get the level of film build and gloss you want.
