Thanks to everyone for your advice. Lots of very good help and I really appreciate it.
So, I just ordered the 3 HP V-series from Oneida. 1,349 CFM at 2.3" SP with filter attached and fan under load. That's twice the rated CFM of my Grizzly and I suspect that it was a generous rating. Oneida's going to do the duct design free!
Mark
Hi mark
Seems like I'm working in parallel, but with slightly different parameters.
Last weekend I managed to get the blower and motor installed in my new "mechanical room" in the attic. (This is in a workshop, separate from the house, way out in the country )
It's made by Jos Poitras (sold to General) No 4 blower. All 235lbs of cast iron, with a huge steel impeller. I bought it used with a 7.5 hp motor for a silly price. It's rated at 2500 CFM at 5". Loud as hell - at least it's in the attic!
Got the electricals going on Sunday, no piping, fired it up. Crap! I didn't want to get near it. Had a small tornado in the room.
Btw. Amazon has relays with 24v trigger circuits that allow you to remotely turn things on/off. So a small switch will be on the lathe, remotely. Didn't want to run large 3ph wiring back and forth.
Btw - running the pipes may be a big part of the effort and expense.
I only plan on using this for sanding on the lathe, since that generates most of the dust in the shop.
This will have 10" dia steel pipe, from the local hvac store, with about 15' run to the cyclone. For the moment, all air will go back into the shop without filters, post cycle - better than now. Once I find a source for filters, those will be added. They're not cheap. In summer, it will be vented outside - no neighbours.
All that sits in my insulated "mechanical room". Btw 52F sounds nice and toasty.
I know this is far from "perfect" but it's much better than now. I've been a software designer and manager for a long time. Often people are looking for perfect. But it's a tough goal. Sometimes just a major improvement is good enough. Heck, it's just a hobby for me.
I sell my work when I can, but it's a ways from paying the bills....
