The fuzzy spots are where you got underneath the wood more than cut across it. You're interested in cutting across the grain and down hill where there's some support in uncut wood behind what you're working. Mostly it's technique. Gouge 101 says you want to take your shaving so that it cuts progressively deeper but gets progressively thinner, until it feathers itself on the edge of the gouge when it leaves the wood.
Most people get the angles right on the outside fairly easily, even though they sometimes end up pulling the tool. Inside really wants a different gouge altogether for the fine trimming. I use the one the old boys used before the metal workers decided we ought to use cylinders, and find it's easier to control because it's easier to support on rest and wood. I like broader radius gouges to get a lot of bevel
lightly on the wood for support. I can lean it left and trail the edge to feather the shaving easily.
Take a look at the angles I use. They will work, with a bit less stability and on a narrow sweet spot, with cylindrical gouges, but if you have a choice, take what is easiest!
http://s108.photobucket.com/albums/n28/MichaelMouse/?action=view¤t=CherryPeelIn.flv
Note a couple of things in the video beyond support and angle. The shavings don't lift, because I'm not underneath them. The only lift comes from the curved shape of the gouge flute, and I'm
not pressing or "riding" the bevel, just leaning it on the work.
It's the same, only easier to visualize, on the outside.
http://s108.photobucket.com/albums/n28/MichaelMouse/?action=view¤t=CherryPeelOut.flv To keep yourself and your work safer, swing the gouge handle to create a continuous surface rather than try to chase an uneven one with your bevel. Finish with the bevel supported.
From above, with a couple of different gouges. Al will like the smaller one, as do I, for the final cuts.
http://s108.photobucket.com/albums/n28/MichaelMouse/?action=view¤t=YY.flv
