- Joined
- Dec 22, 2006
- Messages
- 7,116
- Likes
- 9,843
Still not able to edit my posts.......
Try closing your browser and then restarting it.
For reasons unknown to me, I am now able to edit my posts this morning. Bill, sorry to impact this thread with all this.......you should delete all these off-topic posts. Thanks
Thanks odie,(Ed.....use the "reply" button in the lower right corner, if you want a response directly from me. Otherwise, I may never see your post!.....)
Ed.....the best rpm for me may not be the best rpm for you. There are just too many variables, to make a statement about rpm that would be universal. However, the best rpm for me, would be the highest rpm with the least amount of felt, or "static" vibration......up to a point. There is a point where adding rpm won't be advantageous. Only you can make the determination of what's best for you.
If you want a suggested speed for your 8" Holly bowl, I suspect you may find the best rpm to be around 700-800rpm, or so......and, then to make adjustments, or "fine tune" it from there. It may be higher, and it may be lower. The first indicator is the felt vibrations. If the warp is severe, or the out-of-balance is a significant factor, then those things will come into play in making the determination. There are techniques using both gouges and scrapers for the initial truing of a warped bowl, and they may require different speeds to get the best results.
Here is an interesting thread about "vibrometer", that you may find interesting:
http://aawforum.org/community/index.php?threads/lathe-vibration-detector-ideas-please.14772/
For me, it was an "eye opener", and opened doors to my own methods of fine tuning rpm for the least detectable vibrations.....although, I suspect that many will not find this information of value, unless they have advanced their own skill levels to some degree.....
Thanks odie,
I was looking for a one answer fixes all type of reply, which we all know doesn't happen very often. You caught my attention with the comment about the bowl flexing. I understand the idea of vibration being an element of the equation and appreciate the replies to my question.
Moving on to the next topic.
I recently bought the wolverine sharpening system and a couple of CBN wheels. I retired my Tormek sharpening system because of how long it takes to re purpose a tool. Now I am going through the learning curve with the Wolverine Vari-Grind jig.
The Vari-Grind jig has seven notches that change angle the tool is contacting the wheel. It is not clear to me what angle is being established at each of the notches, or at which point along the axis the notches get locked in.
Lastly, the extension of the tool from the jig, the instructions indicate a distance of 1 3/8 - 2". I started off at 1 3/4" extension and found that I was too close to the center of the wheel which caused the tool to chatter when approaching the heel of the tool. The 2" extension puts me higher on the wheel and eliminates the chatter.
I know I already said lastly but there is one more thing.
How do I measure the angle of the platform to the wheel?
I want to throw out a couple of points for your consideration.
CBN is great for high speed steel, but should not be used for carbon steel tools such as plane blades and carpenter chisels, so it might be wise for you to keep the Tormek for non HSS tools.
Actually, CBN is fine for any 'hardened' steel or metal. This does include bench chisels and plane irons, though you may not want to sharpen a fine plane iron on the coarser CBN wheels. A lawn mower blade is softer metal, and not hardened, and that is what can load up your CBN wheels, along with copper, brass, aluminum, and standard sheet stock.
Thanks odie,
