Max Taylor
In Memoriam
I am searching for a plan-sketch- photo of a tailstock swingaway for my PM3520b powermatic. Are there any out there? Preshate it, thanky, Max
I further assumed that I would be downsizing to a smaller lathe at that point.
Ed
If you've gat a 3520, why would you want to get rid of it just because you are not turning heavy pieces?
Regardless of the size work you do, it is a solid reliable lathe with well thought out features. The only reason I can think to downsize the lathe is to avoid lifting that tailstock (which seems to be the biggest detractor from the PM 3520 design)!
When I read your original post, my first thought was "Why would I want to lift that tailstock after I just busted my gut getting the 90 pound blank on the lathe". Sometimes it is the lighter weight after you strained yourself that will cause back problems.
For many the tailstock weight is prohibitive, for the rest of us it is still a nuisance.
This is to Ed Mc Donnel--When you arrive at the ripe old age of 81 you need all the help you can get. My thought was and still is--as I turn the outside of a bowl, swing the tailstock away and finish the turning, whether it is roughing out or finish turning. If you are turning several bowls, you can see how troublesome removing the tailstock would be. By moving to the end of the lathe, you avoid leaning over so much. something else when you are as far down the river as I am. Heck, Oneway is now making a lathe for people that cant stand very long or stand at all. You will understand these problems as time goes by. Just ribbing you a little. okay? Max
