Stihl Electric
Has anyone used the Stihl MSE 170 chain saw? It's listed at $320 with a 16 inch bar, quite a bit less than the larger one.
Dave Fritz
I have the earlier version of the 16" electric Stihl. It's a pleasure to use compared to the bargain brands.
Thanks for the reply Dale, was that the 140?
Dave Fritz
I'm not able to get to the shop and look at the model # for a few days, but 140 does ring a bell. Seems like the reccomended bar was 14" with 16" as max. Mine has a 16" and does well with a sharp chain.
Southern Wisconsin
Hi Dave - I have a Stihl electric and like a lot.
It has a 16" bar, I don't remember the model.
If you'd like you can come over and try it out.
Montfort, Wisconsin
Hi Tom,
I'm not sure when I'll be up in your neck of the woods on a weekend but thanks so much for the offer. If you get the chance to check I'd be interested in what model it is. I recall you and Dave doing a demo for the club on cutting burls and you used an electric saw. I believe that was a Stihl, was that your saw?
Thanks again, stay warm.
Dave Fritz
Southern Wisconsin
Hi Dave - I have a model MSE 180 with a 16" bar.
I tried to have an 18" bar installed when I bought it but it would work.
Happy turning
Tom
I used mine this AM to prep a 14" dia cherry blank. The blank was frozen quite solid since the temps have been in single digits or below for a while. Worked fine. It's an E14 with a 16" bar.
Montfort, Wisconsin
Dale, an E14. Now that's a new one. Did you get it in the US?
I'm going to have to go to a Stihl dealer and ask about the units you and Tom have. I wonder if they're close to the MSE 170?
Dave Fritz
Dave Fritz
Picked it up used from a Craiglist add. I think it became an E140 before the MSE series came out.
