Stabilizing voids
Tucson, AZ
Newbie disclaimer - I've been turning for less than a year, so I apologize if this is a stupid question / obvious answer.
I've got a gorgeous mesquite burl with several deep voids in it, the most concerning is at the base (see pics). Ordinarily I'd fill it with resin, but my otherwise quite reasonable and intelligent wife has decided she hates resin and since this is a present for her, my hands are tied.
Turning the exterior was fine, but I'm worried that without somehow stabilizing the voids, once I start hollowing the middle the piece will loose structural integrity and break apart (not to brag or anything, but I've managed to become quite proficient at taking beautiful pieces of mesquite and mangling them into unrecognizable fragments and shavings...)
Two thoughts I had -
1) 'Painting' the inside of the voids with CA glue with +/- heavy coating of shellac
2) Wrapping the outside with nylon strap and ratchet to mitigate centripetal forces (this makes sense in my head, I can also see it catastrophically failing in my head)
Any advice? Thanks
Auburn, Alabama
I deal with large voids with a mixture of sawdust and epoxy. When it polymerizes it looks like a bark inclusion. Make dams with masking tape. It may take several applications of the mixture over several days before it's turnable.
La Grange, IL
I don't know the overall solution to your problem, but ratcheting a band of nylon webbing around your piece seems like a bad idea to me. I think that would be dangerously unblanced with the metal ratchet and the nylon webbing wouldn't stay in place due to the conical shape of the piece.
Monofilament straping tape would be a better solution for such an application. But while "banding" your blank would tend to keep fragments from flying apart I don't know that it would be very effective at keeping the piece from fragmenting.
Dave Landers
Estes Park, CO
dlwoodturning.com
The October 2018 American Woodturner had a feature about turning crappy wood. On p28 at the bottom, is a brief insert from Michael Alguire about a technique he calls "Scrap Latching". That just might work for you. I haven't seen any other articles from him about this, but he is scheduled to demo the technique at the Rocky Mountain symposium in September.
The big issue i see is the opening near the base where you have air instead of supporting wood. Keeping the form from blowing up depends on your skill level and the strength or the connecting wood around the void. Light cuts will help. Any hollowing catch will likely end in disaster for the form and possible injury from flying wood.
On the plus side this is an easy form to get an even wall thickness as you can see it in the void.
Note even non Woodturner’s will see the wall thickness and appreciate its evenness.
This opening near the bottom will cause a vibration as you hollow. Leave as much mass in the bottom as long as you can.
Nylon strapping tape will reduce the vibration. Where it crosses the void it will be flat. Depending on the wall you may be cutting the tape as you hollow. A soft wire can be bent around the form to create an arched bridge for the tape over the voids.
Nylon threaded tape will reduce the vibration movement of the void sides.
Ponsford, MN
In my opinion that void is beyond just about any turners abilities to successfully hollow as it stands. I like to fill voids with epoxy putty, however that void would take way to much therefore epoxy or resin is needed. The problem of appearance with resin or putty can be solved by undercutting about 1/16" deep then refilling with finely crushed stone-reconstituted using thin CA. The best choice in my opinion is turquoise which you should be able to find easily in your area.
As an aside that flared base ruins the form so after the piece is hollowed turn away that flare by continuing the curve down to just short of the tenon.
Torrance, CA
How about add the hated resin, turn the vessel and then grind the resin out bringing it back to more of the original look!
Peoria, Illinois
Way back before folks started adding plastic to their work, some turners would freeze a piece with voids into a block of ice. Turn it, then let it thaw out. I'm certain it added no strength to the wood except to reduce vibration.
I know a couple of people who tried frozen water ONCE!
Way too messy for indoors.
Evergreen Park, IlL
Another potential alternative in the "strengthen the outside" category is to turn plywood ring(s) and hot melt glue the ring(s) to the form. After hollowing, the ring(s) should be relatively easy to remove. Good luck.
Dallas, TX
While I 'm not sure what is meant by "Stabilizing voids", if the issue is keeping the log together during hollowing, wrapping with filament tape is a great approach - I do it all the time. And plywood rings are even better, though a bit more cumbersome.
Over the past five years I've focused primarily on mistletoe-burl mesquite - each log is challenging. You might consider the following:
  • Most mistletoe-burl logs are fairly large - it's hard to do a small piece from a log with large "features" (bark inclusions, negative space)
  • While maybe a personal judgement, most mesquite burl lends itself to "axial" rather than "radial" (never like using bowl and spindle to describe hollow-forms)
  • Use a hollowing system where you are not in the line of fire. I've had one piece blow - my ears rang for a few days. I was doing something stupid and not using any filament tape.
  • Learn to see the results before you start. And be ready to reposition the drive and/or live-center as you go. I had to reposition over 1.5" on the live center end and 3/4" on the drive end on the current piece. That means 3" and 1.5" out of round on, in this case, a 200-lb log - not fun.
  • I agree with your wife: large resin fills are to be avoided. If it's an opening, leave it open - if a smaller bark inclusion, fill with black or dark brown epoxy and turn it smooth
  • Finishing is a whole nuther subject - finishing out a hollow form with openings and epoxy fills is, to my thinking, not a place for oils and MinWax.
This is difficult stuff to work - happy to discuss further if you send your contact info to the inbox above.
John
Haubstadt, Indiana
I am not any expert by far. I happen to also have my first burl on my lathe that I just finished hollowing. Significant voids, but not like yours. I wrapped my burl in stretch wrap before hollowing and hollowed at a slower speed than normal. I also used my steady rest. Good luck.
Nebraska
I have a quantity of heavy rubber bands in different diameters that I use for segmented rounds that I have used on several pieces that had some weak spots while turning.
Dallas, TX
William,
That is a great looking piece - the opening and cracks are all enhancements
After it is down to "finishing MC" you might consider shooting (as in needle/syringe) dark tinted epoxy into all cracks in the 1/8" neighborhood and then filling with GFlex from WEST. The large opening would, of course, be the central focus of the finished piece. A 20-ga needle has no problem shooting Aero-Marine #300 - as it appears to be an easily stained species, applying a barrier first would make sense. But forget about sanding the epoxy - you'll have to turn it off as part of final shaping. Any anomalies in the epoxy or areas that need help can be corrected with any filler like TimberMate - you can apply that inbetween coats, again avoiding any bleeding.
And you might want do a rubbed finish - the problem with oil or non-rubbed is that the texture between wood and epoxy can be objectionable - the hand rubbed will give it a soft luster or high finish, which ever looks best to you.
Not sure about the size but it appears to be big enough to carry a "big finish".
The piece deserves the time needed to do a serious finish - it can easily be a piece you'll be showing to prospective galleries if that's the direction you're headed.
