Should I have used sanding sealer?
Fairview Heights, IL
I watched Mick Hanbury use Jo Sonja paints on youtube and decided to give it a try. I used White Ash as that's all I had on hand and I'm curious if I should have used sanding sealer on the top before using the ebonizing laquer to minimize some of the grain pattern underneath the paint or was it just a poor choice of wood to try this on? I'm still happy with the outcome for a first try, just seeing on how to improve.
Thanks,
Tim
Cobden, IL
Thanks,
Tim
Nice piece Tim. Perhaps you could take a piece of scrap and apply both ways to see if it makes a difference?
Pat
Lebanon, Missouri
Grain pattern establishes a piece as authentic wood rather than a photographic reproduction on synthetic material. Let the wood grain dignify your work.
Agree with this.
If you want a smooth surface, use tight grain wood. FYI sanding sealer would take many many coats and sanding back to fill the grain. When you want to fully fill grain like ash/oak use a pore filler.
Nice work!
Clarkston, WA
Absolutely agree ! That why I turn! Seeing the beauty of the grain ! Thanks
