Shellac
Montfort, Wisconsin
I've been reading past posts about quick and shiny finishes and in amongst those are folks who say they mix their own shellac. Now that DNA seems hard to get what do you use to dissolve your shellac flakes and what flakes do you prefer.
Peoria, Illinois
Considering the cost of alcohol right now, I'd suggest just going to Menards and buying premixed shellac. Some folks have even gone to buying Everclear alcohol at the liquor store. That makes for a very expensive finish.
Lebanon, Missouri
DNA is not too bad $ wise here in MO, butShellac flakes are very expensive these days. Use Zinsser Sealcoat dewaxed 2# cut or their Bullseye Shellac, waxed in cans but dewaxed in rattle cans I believe. Unless topcoating with another finish, waxed gives a bit slicker finish.
Roger Wiegand
Wayland, MA
www.carouselorgan.com
I use the Behlen Behkol (AKA Mohawk Shellac Reducer-- they are the same product) quite happily. Find it to be much more consistent than DNA from the big box stores, as the composition of that material changes with the whims of the manufacturer, the price of the inputs, and regulatory changes. It lists at $24/gallon on the Mohawk web site.
None of the online retailers I looked at (Amazon, Rockler, Woodcraft) show any restrictions on shipping it to any state. I bought a gallon just a couple weeks ago in MA.
I doubt I use but a quart of shellac on turnings in a year, so the cost ends up being trivial.
Montfort, Wisconsin
Thanks for the replies. I don't use much anyway, I'll just get it in the can. I do like to use it as a sanding sealer before applying color is some woods. I saw too that Ernie Conover uses household ammonia to clean his brush after using shellac. Anyone else use it as a solvent for cleaning up shellac?
Bay Settlement, WI
I just bought a gallon of DNA at my local Menards for under $15. Not really expensive and not hard to find in my area (NE Wisconsin).
Nebraska
Too cut down on the cleaning solvent for your Shellac brushes, you can use a small plastic bottle with a large diameter screw on lid and leave an inch of solvent in the bottom of the bottle and store your Shellac brush inside the bottle submerged in the solvent. I usually use a 1-inch chip brush to apply the Shellac and this is small enough to fit inside the neck of the bottle. The solvent is the same chemical used for thinning the cut of the Shellac, once each year or two I buy a new plastic bottle that the thinner is sold in and throw out the old one when it needs to be replaced.
Roger Wiegand
Wayland, MA
You don't need to clean your shellac brush particularly well, I give it a couple squirts with DNA from a wash bottle and blot it on a paper towel, just enough so it doesn't harden into a brick (if the latter happens it just takes longer for the solvent to get to dissolve the shellac residue). The bristles will be stiff, but then the residual shellac will soften very quickly the next time you use the brush. Because the shellac re-dissolves there's no issue with dried finish particles marring your finish as occurs with varnishes and such of the brush isn't completely clean.
Lebanon, Missouri
Does amonia break down shellac?
Yes. Would not want to use ammonia containing cleaner on a shellac finish to clean. It wont do much if immediately wiped off, but will strip it if left on long enough. Ive taken a brush that was very crusty with cured shellac, spray soaked with ammonia, brush came out squeaky clean. I probably kept it wet for over an hour maybe longer.
Cleveland, Tennessee
I do just the opposite. I buy relatively cheap brushes and rollers for any paint or finish. If I'm using the brush or roller over a few days, I'll wrap it in a plastic grocery bag. Otherwise, it's easier to toss them than spend the time cleaning them. JMHO.
