- Joined
- Dec 22, 2006
- Messages
- 7,123
- Likes
- 9,888
The post concerning the accident Lynn Yamaguchi had at her lathe recently, has brought back a thought I had a few years ago, but never acted on it.......I think I've seen and heard enough of these personal injuries from lathe turners to finally do something for my own protection.......
Since I've been participating on these AAW forums, very serious accidents have been all too common. Probably at least once or twice a year, someone has been very seriously injured, and it has been reported here.....and if I'm not mistaken, there was one death a couple years ago.
It seems to me that most all of the more serious injuries were caused by partially turned blocks of wood that flew apart while the wood was still very heavy and solid. Before roughing is completed, the centrifugal forces are tremendous, because of the added weight involved. After the roughing stage, it appears as if the likelihood of the wood coming apart is greatly reduced.... (but not eliminated, of course!) A "catch" could always be a cause for bowl to break, no matter what stage of completion.......
For years, I've contemplated getting a football helmet with wire cage for protection at the lathe during the roughing stage of some "suspect" problem bowls. After looking over football, hockey, and lacrosse helmets, I've decided the overall best cage designs are on the helmets designed for ice hockey. The cages here seem to be better suited, because of the tighter mesh of the wire cage.
In trying to anticipate comments from one of our members here.....I realize the common safety precaution for turners is to simply stay out of the "line of fire" when turning.......but, there are times when I'd prefer to have the best view of what I'm doing, and the best positioning of my body for the cutting I'm doing at the moment.......therefore, having the hockey helmet is a safety measure that allows that preference, and covers the safety concerns to what seems like an adequate degree. (I've never tried the helmet, so I'm making assumptions on it's application, for the moment.)
Having this hockey helmet is going to reduce the "pucker factor" I'm sure most all of us have felt from time to time. Since I don't intend to use it in every case, but a few that seem likely to be problematic, there is still a certain amount of gamble I'm willing to take........but, the odds of my avoiding an injury will be greatly improved! :cool2:
I anticipate not using, or needing the chin strap. Hopefully I'll be able to use my Resp-o-rator while using the helmet, but if removal of the chin strap doesn't give enough room for that, the cage itself can be modified somewhat to allow for it......I think.
Any comments on this is certainly encouraged......thanks!
Here is a photo of the type of ice hockey helmet I'm in the market to purchase:
