I have some logs that were cut about two weeks ago. Right now, they are in an outside storage building. I have about a gallon of Anchor Seal and wonder if there is something else that can be used when the AS is gone. Thanks.
I agree John. Never looked back since I started using Anchorseal. Sometimes WC has it on sale and I try to buy a few gallons when on sale.Anchorseal works best.
Has anyone ever tried vacuum packing to prevent drying? I was thinking of trying it . I have 18” wide rolls that Could accommodate about 11 inch logs.
John Is canning wax same as Paraffin wax?Bill I have really good success using canning wax
Reed, I've read where lot of turners use Elmer's white glue for sealing. Noticed Wal Mart had Elmer's glue on sale for $11.00 a gallon the other day.I have also used titebond as a sealer on smaller spindle blanks and it works pretty good. No idea how it compares price wise.
I always enjoy reading the threads about what to do with cut logs. Seems to be a never ending story. Problem is that the advice from someone in Phoenix won't work for someone in Portland. I have so much wood that I can't afford to use anchor seal, nor to spend hours painting the ends, but, I'm lucky, I don't have to. I can see the rain the forest from my house... I just cut the logs a little wider, I hardly loose any of the common woods that I use. Some, no matter what you do they Crack beyond recognition, like Macadamia Nut... I can see been an important issue when you only have little wood... Anchor seal because of the shipping is very expensive here, I reserve it's use for some rough turned blanks, and seldom I paint a curly Koa log that's worth $120 a board foot with latex paint, seems to works just as good as AS.That won't work ... at least not in the way that you hope it will. Here is what will happen:
I prefer Anchorseal and so far, I haven't found anything that beats it for my local climate. There are some places (Hawaii and Gulf Coast, for example) where Anchorseal might slow down the rate of evaporation too much and lead to molding. I have used plastic stretch wrap a few times and if I leave it on for more than a few days the wood turns black with mold. My wife had practically cornered the world wax market judging by all the candles we have, but my experience with paraffin wax has been less than encouraging ... and for me it's a big mess ... some wax on the wood, a lot of wax on my clothing and shoes, and even more wax on the driveway.
- First you put the wet wood in a plastic bag, seal it and then use a vacuum pump to remove the air. And, then . . . .
- The first thing that you encounter is you can't seem to evacuate the bag. (scratch head and say hmm)
- What is going on?
- First of all, there may be a lot of air in the wood unless it is a green tree that has been cut in the last day or two. The entrapped air takes a long time to be drawn out.
- Second and more importantly, the wood is full of water and as soon as the pressure begins to drop, the liquid water is no longer in equilibrium with the water vapor pressure inside the sealed bag environment. This will cause liquid water to evaporate out of the wood until the pressure inside the bag is exactly the same as atmospheric pressure outside the bag.
- So, being tenacious, we decide to just run the vacuum pump a little longer. But we will realize sooner or later that as long as there is any moisture in the wood, the water will continue to evaporate as long as we run the vacuum pump and we will wind up with the same pressure inside the bag as it is outside the bag ... that is, until the vacuum pump sucks the wood completely dry of any moisture .... but, that sorts of defeats the whole point of keeping the wood from drying out too fast.
- The bottom line is it will only serve to suck moisture out of the wood faster than it would otherwise evaporate and, at the very best, won't any better that putting the log in an ordinary plastic bag.
Thanks for that info Bill.Canning wax is one type of paraffin wax and what we are most likely to encounter.
I like that John, that's a good idea! Lot faster that way!That's what I do. I buy the stuff in gallon jugs and just rub it on with my hands. I used to use a paintbrush, but it's too slow. Now, I just sort of give rough bowls and blanks an Elmers massage.
I have it on my phone to seal the logs this afternoon after it cools off a bit.
Have you tried keeping kiave (aka camelthorn), imported by the early missionaries to keep the natives from jumping in the bushes on impulse and going "ka launa puana" or "paani-paani", ....from splitting and cracking?I always enjoy reading the threads about what to do with cut logs. Seems to be a never ending story. Problem is that the advice from someone in Phoenix won't work for someone in Portland. I have so much wood that I can't afford to use anchor seal, nor to spend hours painting the ends, but, I'm lucky, I don't have to. I can see the rain the forest from my house... I just cut the logs a little wider, I hardly loose any of the common woods that I use. Some, no matter what you do they Crack beyond recognition, like Macadamia Nut... I can see been an important issue when you only have little wood... Anchor seal because of the shipping is very expensive here, I reserve it's use for some rough turned blanks, and seldom I paint a curly Koa log that's worth $120 a board foot with latex paint, seems to works just as good as AS.
