Rough turned bowls cracking
Bloomfield, New Jersey
I'm learning. Lot's of good advice here. I guess I need some help slabbing as I'm very slow with a these wonderful disabilities. I'm going to make a sawbuck that I can roll logs onto and get a better position for slabbing. I have almost a whole cherry tree with some of the pieces weighing well over 200 lbs. So far, after keeping them in the yard on pallets, with a tarp over them, none have started checking yet; but I am NOT looking forward to handling them!
Hit youtube for videos of people prepping blanks or moving logs without machinery. You can do more than you think with some rope and long, sturdy levers.
View: https://www.youtube.com/watch?v=awjSqpUQUVQ
The next two are from The Survival Sherpa - Good stuff.
View: https://www.youtube.com/watch?v=HkV7-jf1pEM
www.youtube.com/watch?v=QFDGGht3CQU
Shingletown CA
I turned this yellow old growth cedar bowl today. 12% moisture reading, and it still cracked like grandma's skin. I could literally see the shallow cracks appear as I sanded it. To the junk pile yet again!
Timothy Allen
Maine
Are those cracks or are they some sort of ray? Look carefully at how they interact with the grain -- maybe those are a "feature" not a defect?
Shingletown CA
They were not there when I started sanding. They developed about half way through 80 to 120 grit
Shingletown CA
350 rpm with a kinetic sander. The wood was outside in the weather and I probably did not let it stabilize long enough.
Gainesville, VA
View attachment 33937 View attachment 33938
I'm not sure what kind of cedar that you are turning here but there might not be anything you can do to stop it from cracking. As I have stated on many occasions, the Red Eastern Cedar that we have here in Virginia is the "king of cracked wood." You just can't stop it from cracking. On several occasions I have heard it cracking while it was just sitting on the lathe (not turning and my shop tunes were turned down a bit). It is a beautiful wood and I'm always experimenting with it (right now I have a chunk rubbed in cedar oil)...but it is definitely going to crack no matter what you do to stop it. My best fix so far is to do what Gerald recommends...expect the cracks, get to know your cedar cracks (ha), and then flood the heck out of them with black CA glue and hope it looks "artsy" when you put some finish on it. Sometimes it works...
Shingletown CA
Cracking accepted; but of course the mortise failed and it went flying. I've had that happen to several pieces of cedar; guess I should have used a big tenon.
Well, if I was there while you were turning it, before you started sanding, I may have been able to see those cracks. I will agree that they look like they were already there. Being able to see them is a skill you develop as you get more experience. The heat checking you get from abrasives tend to look similar, but they are generally much smaller checks, and more wide spread. You can 'thump' a bowl on the lathe to see if it has cracks. One with no cracks will ring like a bell. One with cracks will just have a dull thump sound. Some times you can hear the cracks rattle.
The mortise is high risk with wood like cedar that is easy to split.
You can break a mortise in cedar with too heavy a cut and most minor catches will break it.
a tenon will hold better but will still fail with a catch.
keep paying attention to the tools.
It takes practice and you will get to the point that one day you will think, “ gee I can’t remember the last time I had a catch” , Because it will have been many months or a few years past.
Catches are not part of Woodturning. They are the result of poor instruction. When we teach ourselves ( I was self taught) we have a pretty inexperienced teacher....
