Proedge question
Shingletown CA
I am getting my second proedge sharpener (first OB was trashed by FedEx); and was wondering if there is a good product to stick on the platten to reduce friction On the belt? I had a oscillating edge sander that had some kind of pad on the cast iron platten and it greatly increased the life of the belt. I’m just picking the knowledge base here, as it is very helpful.
I am not sure how those interface pads work on belt grinders. I have a Jet 1 1/2 hp belt sander and after about 3 days of sanding some metal parts the pad was very worn and uneven. Not sure if they make some thing for 'industrial' type of use and abuse. I do make my tools work up a sweat when I use them.
Tom Gall
Hillsborough, NJ
I have these graphite platen sheets installed on my 6"x48" belt sander since 1997 - don't think I've ever had to replace it. Granted, I don't use it very often anymore but it used to get a lot of use. Also cut a piece for the platens on my 1" belt sanders. I purchased the 6x18 (3) from Woodworker's Supply in '97 and still have at least one sheet left. They were only $18.95 23 years ago. :D
https://woodworker.com/4-wide-graphite-canvas-mssu-919-610.asp
