PowerMatic 3520C Initial Review: My Mustard Monster aka "The Beast"
I have been looking into this system. Did you get it from craft-supply? This system is kinda pricey but I like the concept. I understand the swivel for the dust shoot does not come with it and has to be purchased separately?
Yes, Greg-I got it form Craft Supply. I do agree it is pricey, but it definitely works better than anything I could have rigged up. No, there is no swivel attachment. Their instructions recommend the Rikon version. Dennis, I will go out to my shop and take a picture of how it attaches, and report back. Their instructions are confusing, and it took some figuring.
Aaron how is the aluminum track attached to the lathe? Is it PM or other?
Thanks
Dennis.
Dennis-The instructions on the Black Hole system give three mounting options depending on the lathe, one of which is to drill holes for the mounting screws, which I didn't want to try. I went with the included mounting clamps that tighten down under the lathe bed. It is sturdy enough in actual use, though it seems vulnerable to breakage at the bottom arm pivot and the one with the hose hanger if, say, you fell or dropped a heavy wood blank against it. And attached to the massive cast-iron lathe, it's almost laughable by comparison, but it is what it is, and dramatically improved my dust-collecting situation. Here are three pics to give you a better idea:
View from under the lathe bed with aluminum track installed
Another view from underneath
Down along the rail at the two clamps
I hope this helps for anyone else considering this option. Happy Holidays all! Aaron
Regarding black hole dust arm--
How sturdy is the system? Seems like a lot of plastic in the key area's for support? particularly the angle bracket that actually attaches to the rail. Would think metal would be better option.
Dust collection - didnt like mounting a dc hood to the lathe, like the black hole. Rockler has a version that allows many mounting options off the lathe
It does have an achillea’s heel. The corner joint for the vertical and horizontal pipes is weak, unable to support the arm. I added a $7 modification (bracket and 2 hose clamps)that maintains all the motion of the system and reinforces the corner:
Thanks Aaron, the aluminum brackets look like they are solid enough and track looks good also, but like others have said the plastic is the weakest link. I have since ,my message to you, looked at woodturnerswonders track system metal track metal fastening clips and metal brackets for the lights and dust collector shroud. Its cheaper and i think it looks like its more solid, so i think iam going to get his system.
Best to You Arron
Dennis
Best to You Arron
Dennis
I have had the system from Woodturners Wonders for a couple of years now ... very happy with it. Bought it first for my PM3520C, then bought a second setup for my PM2014.
Great GR, glad to know that you are happy with it and by the tact that you bought another speaks highly of the system. thanks for letting me know.
Best
Dennis
I've had my 3520C for about 2 1/2 years now and I still feel warm & fuzzy about it. Feels a little odd to have affection for a big chunk of metal, but it's provided a lot of nice time spent turning. Haven't had a single problem with it and any failed turnings have been my fault. I'm generally left handed and have found that hollowing at the end of the bed is much nicer. I have the tailstock swing-away and found that a loop of rope around the quill handle and hooked to a nearby 2x4 pulls the tailstock further around the pivot and more out of the way.
Enjoy "the Beast" and keep it well fed with blanks and you'll be friends for years to come!
Hi, Ric, concerning the PM swing away you have , do you also have the 18" extension? By pulling the swing away with the rope do you think the 18" extension on the lower setting for larger turnings would work without the swing away getting in the way of turning on the low extension setting on the leg.?
Hey Dennis,
I don't have the extension, so I can't state it definitively, but I think it would work with the extension in the lower mounting position, with or without pulling the tailstock all the way around. The only reason I pull it back a little farther, so it does a full 180 degree swing, is to avoid banging into it when I'm working off the end of the lathe.
I have been wondering how this would work. https://www.amazon.com/gp/aw/d/B07NH9TDHC#Ask
Seems to have plenty of beef, and easy to reposition for way less than mounts made specifically for turning.
I used a similar monitor arm, which I clamped to a light weight saw horse. It works fine, but in my application the articulated monitor support can't lft the "weight" of the dust collection hood & hose. So I don't have much adjustability vertically. Lateral adjustment is either via the arm or just moving the saw horse. Vertical adjustment is not that critical once I put the hood at the right height. All in all, it works well enough.
This is an old picture. The lathe has since been moved, and the saw horse parallels the bed.
I just converted to using this articulated arm. It’s made for holding dock lights or fans, but it’s easy to attach anything you want and it’s really strong. I really like that it doesn’t get in the way of the banjo at all and it can easily range from one end of the lathe to the other. At some point I’ll probably change out the dust hood to a bell shape, but this will do in the meantime.2F1D8991-7879-45C7-9B1B-0EFB4B08730C.jpeg060D3725-8142-4DB6-9042-719372C9FC0E.jpeg
