Al   When I did my skew testing I tried all sorts of angles.  The really sharp angle of 25 degree included angle cuts like a breeze but can be really catchy if you don't pay lots of attention.  I found that a skew ground to 35 or 45 much easier for beginners to use.   I have mine ground to 30.  That gives a good edge that holds an edge well without chipping on harder woods but stills cuts very easily.     The nice thing about a sharper angle with the skew is that you don't have to move the tool handle as far when rolling a bead.  The bad side is if you come off the bevel and get a run back it digs in more than a blunter skew and ruins the bead.
With my spindle roughing gouge catches just aren't much of a problem even with the sharper edge. It's just the sharper edge is too fragile. I notice a lot of spindle roughing gouges come from the factory with a really really blunt edge. Sometimes about 70 degrees or so. I guess if you use it as a scraper rather than bevel rubbing tool then you want that blunt edge so you can use the burr.
