Oneway Easy Core post height
Fairlawn, Virginia
Would someone with a 16" and 20" Easy Core please measure the height of their white painted posts? Looking for the measurement from the top of the base plate to the top of the hollow post.
Thanks
Midland, MI
I have a 20" unit. The white column (hollow post) that holds the cutter knife extends slightly less than 6 3/8" above the top of the base plate. The white column that holds the support finger extends about 5 13/16" above the top of the base plate.
I'm curious why this matters to you.
Dave
You need a different base for 16 inch lathes and 20 inch lathes... The 16 inch base will not work on a 20 inch lathe because there is not enough post to properly support the coring arm and support arm.
Fairlawn, Virginia
Exactly, that is why I want to know the correct height for the posts. I am looking at buying one used and I want to be sure it is the right one for a 20" swing. The person is selling it from their father's estate, so I just want to be sure it is what he says it is, since he wasn't the user. Thanks
Emiliano Achaval
Maui, Hawaii
hawaiiankoaturner.com
Thanks
I once had to ask Oneway something. Years ago. I was impressed by how quickly they got to me. Call them or email them. Very nice small company.
Fairlawn, Virginia
Dave - Thanks for measuring. Your measurements match up to the one that I am buying, so I believe that I am good.
What threw me off was that there were 1" (roughly) long steel plugs in both posts. That's what made me think that maybe these posts were for a 16" swing lathe. But, it makes sense after thinking about it. All the knives and support fingers from Oneway are the same, so you would need a plug in there for the taller versions of the posts for 20" and 24" swing lathes. Of the many videos that I watched on the Easy Core, I never heard the plugs mentioned. Anyway, I bought it and it worked great, cored out a walnut bowl last night with no problems.
Fairlawn, Virginia
Gary - Mine has both. With mine, the threaded studs aren't long enough without using the plugs in the bottom of the posts. Is that normal? I believe mine could be an old set because the cutter tips still had the old straight grind.
Glenn Lucas made some nifty handles that attach to the adjustment nuts on the bases so you don't have to dig out the wrenches to move or advance the support finger. Good idea, but I think that rather than buy, I would make my own...
