Older JDS 2000 Air Filter
Montfort, Wisconsin
The pull cord on this unit broke off inside the filter today when I pulled it to turn it on. It has two speeds which were controlled by pulling the cord. Actually quite surprised it hasn't worn out before. I opened the unit up and this is what I found: switch.jpgswitch 2.jpg
I was hoping I could by pass the switch and control the unit on and off with a remote at the power supply. I'm not very good with electrical things and would appreciate your thoughts on this matter. Thank you.
A little google'n indicates the switch should be marked L, 1, and 2 where the wires go in. The two "on" positions connect L-1 or L-2. Which is high and low depends on the order the switch rotates thru. L is going to be line (from the wall cord) and 1 and 2 will go to the motor. L is probably black if I'm seeing your photo right and they followed conventions. You should be able to connect the L wire to 1, see if that's the speed you want (if not, connect to 2). If you connect the 2 wrong ones together (1-2 that both go to the motor) nothing will happen. If the terminal connectors that are there won't mate together, you'll have to snip/strip and use the proper size wire nut.
Obvs unplug everything first. And cap off or tape or otherwise safely insulate the other wire.
All else fails a replacement is like $8 on amazon - look for "ze-228s"
Piling on to Dave's information above. This is a link to an Amazon switch that includes installation instructions. From what I can tell the electrical connections are friction fit (pull out / push in). I interpret the instruction to use a small screwdriver as meaning to use the screwdriver as a lever/pry bar to reduce the friction on the wire. I'm confident that if you follow the instructions you'll be successful.
Good luck!
I have the same unit. There should be a wiring diagram inside where you took the plate off too get at the switch. I replaced it with toggle switch from HD with a center "off" or NO and NC to the right and left.
Thank you everyone. I just got back from Menards and again I assumed the sales guy was experienced. Wrong-he gave me a 3 speed switch, not a 2 speed, which they have in stock. I guess I could call this an education as I'm learning alot about ceiling fan switches. My bad, I should have looked more closely.
When the motherboard with the IR receiver for my filter failed, I just retired the remote, got a generic three speed switch and wired it to a switch box near where I work.
I have been an elelctrician for 35 years. the 3 speed switch will work. You just tape off-wirenut the extra wire. It is important to carefully match the wire color to the same lettered loction so it matches the original switch. Be careful and it will work out fine.
Dave,
I found out a fellow member of the woodworkers guild I belong to had retired after a career as a commercial electrician - mainly industrial controls and building electrification. He has become a great resource when I am unsure of how to approach a situation (he’s great with VFDs, too!).
I took the three pull back and found the two pull, not in the ceiling fan area, rather the lighting area. With the help of my wife and a $4.45 part we're back in business. I still think I'll use a spare remote and use that since I only run the unit on one speed anyway. Thanks for your input. BTW, we got a break in the weather and my neighbor just said he saw a bluebird. Lots of birdwatching ahead.
