i just had 15 logs shipped to my house from florida, some of the 20" in diameter. i have turned one and it came out pretty good for my first. it's just hard to get a hold of it here in california.
i'd post a pic, but i am too lazy right now to shrnk down the pics.
i have fun turning it, but i came across some local pine with lots of spalting. the only thing, knots are very desired in NIP turning, the regular pine one only has one. but both look so similar.
i rough turn the blak to about 3/4", then i soak it over night in a solution of 1 part water, 1 part kirkland(costco) dishwashing liquid. i have a 32 gallon trash can with about 22 gallons of liquid in it. that helps to stop cracking and warping. then the next day i finish turn it to about 3/32 to 1/8" and bath it in watco. i'll mix my own soon, but for now, watco is it. so far i use a 5 gallon bucket with 4 gallons of finish, but i am looking for a container to get about 15 or 20 gallons of finish in it, just need something that's about 24" x24" x24" or so.
i soak it in there for 12 hours, then pull it out and let dry for 12 hours. repeat as many times as you want.every time i pull it out, i wet sand with the oil on.
final step, when it's dry, i buff it with steel wool so it's smooth as glass and apply 3 coats of arm-r-seal. let dry for 24 hours and buff on the wheels.
they get pretty translucent.
for more info,
www.ronkent.com
i can't wait to turn my large pieces, but my nova is being replaced with a stubby 1000 on wednesday, so now i just need to sell the nova dvr. then i'll make huge NIP bowls
hope that helps
sascha
