New life to old wood
www.regenbogenwoodturning.com
Hey, A friend gave me a chunk of an old dogwood to turn since the tree had sentimental value to his wife. I think the wood had been cut about 3 years ago, and it is really dry. I've turned dogwood before, but when it was green, and had good luck with the bowls that came from that log. Does anyone know if you can bring some moisture back to a chunk of wood so that turning it will be less of a fight? Like can it be soaked in something to soften it, without the wood blowing to pieces? In other words, can I treat some old dog with some new tricks? Sorry, but you saw that coming. But seriously, can a chunk be reconstituted in any way?
billerica, ma
Once she's dry, she's dry Scott. I'd just recommend very light cuts and taking your time. Higher speeds when cutting also help a bit with keeping the cuts really light. Sharpen often and, if you're getting tear out, lube the spots up with paste wax before final cut.
And well dried and stable dogwood is quite a find so enjoy!
Dietrich
Less a bit of "fiber set," storing in high humidity can bring back the same problems and the same joys that turning green wood presents.
Try something like glycerine (LDD) which will soften the surface a bit while not evaporating as rapidly as water if that dogwood is still biting you. I'd use the topical versus the full-time soak. Paint it on, let it soak, turn, repeat as required. Let cure some extra time afterward before finishing.
new life / old dogwood
Well I finished this piece and have posted a shot of it. Overall the suggestion to take light cuts, use a high speed and sharpen often proved the right way to go in this case. Thanks for the input and I'd welcome any feedback. I wasn't as crazy about this piece as I was the other dogwood pieces that I've done due to the size and shape of the blank I had to work with, but it was free wood, and free is me. Wee.:cool2:
Haslett, Michigan
pictures
ok, this is computer illiterate Gretch here. This is the second time (scotts) where a poster says I have posted a picture, and none is there. How do I go about finding it?? Gretch
Martinsville, VA
pictures
usually your file size is too large, you can check by going to my computer then to the file you want to upload, hit view , then details, look out at the right of the file name and it will tell you how large your file is, if your picture is jpg file it has to be less than 97.7 if it is not go to your picture software, bring up your picture, hit format, then under format hit resize picture, you want to change the inches to around 5 x 4 leave the pixels alone, then resave the picture under the same name or another name your choice:D
the directions on uploading a picture are in the help part, i think under manage attachments which is below where the text is, that is where you do it
opps i think Ed understood what you were asking
