With some creative rearranging I can finally get a bigger lathe, even larger than the Nova I was looking at. However there is still an issue of mobility I need to try to overcome. I could have it just up against the wall but I'b be working in direct sunlight after 1 in the afternoon and that gets a bit warm this time of year.
Does anyone have suggestions on how to make this lathe mobile?
I've been thinking of using industrial casters under each leg, either directly attached or on a wooden platform I could slide under the legs. I've also thought of trying to develop some combination of casters and levelling feet where I could use the feet to drop it onto the casters, move it and use the feet to raise it, or have the caster move up ad down.
Thanks!
Gerry
Thanks!
Gerry
