Someone posted in a thread showing a magnetic thickness checker that uses a small steel ball on the opposite side. I cant find the thread. I wanted to research the device. Any help?
Absolutely… but dont hold your breath. At north of $200 I wont be participating. I will research it to understand it better. I have many calipers that work well, and an excellent bottom thickness gauge using a laser that I cobbled together, so I have better uses for that kind of $. The use of the technology in this application is interesting.Doug, if you get one and try it out, would you post on here an explanation of how it works?
No. They use a hall effect sensor that uses the magnetic field change caused by the distance the rare earth magnet is located (the ball in this case). Any non magnetic material can be checked.Would the different wood densities give one a different reading?
