Got to spend some time on the lathe last w-e and confronted a rather strange situation.
Have some dead-green walnut and decided to rough out a few HF's and bowls. Had one blank about 20" wide by 12" thick. The initial roughing went well enough, and I decided to do a closed form rather than a deep bowl. Got the profile done with a faceplate, removed it and chucked it in the vic 120 with a 5" tenon. Brought up the TS and re-trued the profile so all was running smoothly. All pretty usual.
I removed the ts and started to open the form with my bowl gouge. Moving into the form I started to get this low frequency vibration from the cut. Not the first time I've gotten a rubbing sound from wet wood, but as I kept making cuts the noise got stronger and all of a sudden my lathe (850lb Stubby 1000) started to dance like the piece was way out of balance. Huh? I stopped the lathe to see if the piece had slipped in the chuck, but all was well and the profile was dead true with no wobble. Turned the lathe back on and everything ran smooth. Take another couple of cuts and, first the sound, and then we're dancing again!
This appears to be a turner's example of induced harmonic resonance from the vibration in the cut setting my pile of steel to music. There's no doubt that if I hadn't stopped the lathe to check this out, my lathe could have easily oscillated out of control and I could have gotten hurt.
Moral of the story: When your lathe talks to you, you better listen.
