Kiln drying time
Old Saybrook, CT
I have found a local place that offers kiln drying of your wood. I was thinking about having several bowl blanks dried, they are about 10"x10"x5" black walnut and some cherry. Any ideas as to how long this might take?
Also wondering if there is an acceptable way of quickly drying these myself?
Thanks,
Martin
Show the kiln company. They will be able to answer your questions. You might make a friend and find a wood source.
Peoria, Illinois
What is the moisture level now? 5" wet cherry will come out of conventional kiln as a piece of firewood. The only way to kiln dry 5" lumber quickly is by using a vacuum kiln. I'm kiln drying that thick of timber right now, but I cut it in 2010.
You can rough turn the bowl 10” diameter with 1” thick wall. Day 1
The dry it in the microwave. You have to watch the bowl and do multiple cycles Day 2
Then finish turn day 3
Here are several microwave methods.
You might be interested in looking at this thread on working with green wood.
It’s from a demo I did where I rough turn a bowl from green wood and finish turn a dry warped bowl.
Standard kilns do not do well with any wood over about 8/4 or 2 inch thick. Difficult to get equilibrium, which leads to cracks. Far easier to rough turn, seal, and dry on a shelf. A vacuum kiln will work better. Also, different woods dry at different rates, so if the kiln is running one kind of wood and yours is different, then results are not guaranteed.
