We've had two days and nights of intermittent heavy thunderstorms here in Lancaster and the power has gone out in this neighborhood several times, most recently overnight.
After resetting all the clocks in the house, I went out to the shop to work, pulled the red button on my Jet and ... nothing. Digital RMP display is reading zero. Uh oh. Push the button off, pull on... nothing. Crank the speed control, toggle the direction switch, nothing. Unplug the power, wait a bit, plug it back in, try again... nothing. Big UH, OH. Spin the spindle by hand and the RMP readout does work. ?? Scratching my head I locate the manual, check the troubleshooting guide. As expected, no useful information.
Then it dawned on me to check the Ground Fault Interrupt on the outlet. I know some people have reported that their variable speed controllers will not work at all on a GFI protected outlet but I always poo-pooed that because mine works fine. I don't understand why the motor won't spin if the circuit is supplying voltage but I reset the GFI switch on the outlet anyway and, ta daaa! I'm back in business and nothing appears amiss.
Just wanted to share this bit of arcane knowledge. Back to work!
