As a very new member, I've very much enjoyed my first two days here, reading as many threads as I can. Taking a slight break at work, I can't believe I'm getting paid to visit here! (for a short while)
I'm confused. I'm a novice turner, using a Jet 1236. When does it become necessary, or conventient, to turn the headstock around 180 and use the short bed. I have an adaptor, like an extra arm, for use in the banjo that would allow me to use the rest at an extended reach, I'm assuming while it's mounted on the short bed.
Second, is it normal to lean half way over the bed to gouge out a bowl under the lip. (leaning way out to the right to get the tool inside on the left) Is there another way.
By turning the heastock off axis, is that considered "outboard turning?"
I have Kieth Rowley's book, I believe he doesn't go into this much at all.
