How much of a lathe would I need for this turning?
Chicago, IL
Hello - I'm looking to purchase my first wood lathe to make "ACORN" finials for a table I'm setting up for production. Looking for advice on how much Horse Power in a lathe I should get to efficiently turn these acorns. I'm thinking a mini or midi lathe. I'll probably make a dozen acorns at a time (not on the same blank, but twelve total). The acorns will be made of white oak. Any suggestions on how much H.P. I need? Thanks.
Well, any of the mini lathes out there should work, and to me, mini is a 12 inch lathe. I would expect them to have better resale value, if it comes to that. I would check with the local club there and see if some one has a lathe you can get used rather than new. You could probably pick up some tools as well. I figure the lathe is about 1/4 the cost of 'things' you will need to start turning.... Sharpening system, tools, abrasives, finishing stuff, grinder, chuck, though not essential, it really comes in handy. A work bench for the lathe, dust collection, safety gear, maybe a bandsaw......
You could easily turn 2 at a time from 10” blank.
This may not offer a speed increase if there is something like a dowel joint planned to pout them on something like a bedpost
Then a twist lock pin chuck would be real quick and automatically center on the hole.
A screw chuck would work too.
Any midi of mini would work. A 1hp will make the roughing from square to round faster and easier than a 1/2 hp.
La Grange, IL
I suggest the Jet 1221 EVS. It has most all the features you'd want in a lathe for this and future projects. Variable speed, reversible, can turn very slow & very fast. Small enough that a movable headstock won't be missed. Good resale and you can find them used as people step up.
Lebanon, Missouri
I suspect you many want them “duplicated” as closely as possible. As this is your only reason for getting a lathe, I’d recommend a duplicator lathe or an add on duplicator. It depends on how close of a match you want.
This is not a great lathe in general, but for the light work you are after its fine IMO:
Grizzly and others make “copy” or “duplicator attachements” to fit some different lathe sizes as well.
The copy process uses a scraping cutter which can leave a not so great finish, which could then be scraped in with shear scraping or negative rake scraping with some finish sanding.
You can use a flat template to guide the copy attachment, or a full part.
Roscoe, Illinois
My first lathe was a Nova Comet II Midi Lathe. It worked great and was designed to handle up to 12" diameter blanks so this would work well. It's a little bit of a step up from most mini lathes, I think, as it has speed control with 3 pulley speed ranges, so doesn't involve a lot of changing pulleys to move to a different speed. Pricewise, I don't know how it would stack up against most mini's these days.
Chicago, IL
Thanks for all your information, helpful in making purchase. I found a Rikon 70-150 on sale at Acme Tools ($625 incl. shipping - a very good price, usually sells around $750-850). It has 1 hp and variable speed and 12" X 16-1/2".
Chicago, IL
Hockenbery - I do need to put a dowel hole at the bottom of the acorns. And I am looking into your ideas of a twist lock pin chuck or a screw chuck. Otherwise I'm thinking I'll have to build some sort of jig to hold the acorn in place while I drill the dowel hoes. Thanks.
Tom Gall
Hillsborough, NJ
I think he means to drill the hole first - all turning will then be centered on the hole.
If possible drilling holes before turning is best.
Using a screw center that matches a dowel diameter makes it easy to center the turning on the hole.
Sometimes finials are attached with metal fasteners.
Making a useable screw chuck is simple with a faceplate, block of wood and a lag screw.
Evanston, IL USA
When I did production work making newel post finials in acorn shapes, or ball shapes, whatever, I most often turned a round tenon (dowel) as a part of the whole piece when roughing down to approximate size. Then I would mount the dowel in a 4 jaw chuck for completing the entire finial. The advantage to that was that I could make tenons that were fairly large diameter.
If you care to travel to Evanston, I could give you a demo if you are interested.
