Hovercraft, (partially) turned on the lathe
Chicago, IL
I imagine I'll take some ribbing for this post, but here it goes anyway.
I remember as a kid buying hovercraft plans that were advertised in Boy's Life, but couldn't make one since my parents wouldn't let me "borrow" their vacuum cleaner for the motor. This fall I bought a cheap cordless leaf blower and it reminded me that you could build a hovercraft with one of these. Surprisingly, the web is full of plans if you google "leaf blower + hovercraft". The link that I found most helpful is http://amasci.com/amateur/hovercft.html, but there are lots of alternative plans out there.
This project only has a few items of woodturning in it -- but in case some of you are interested I've posted a few photos and a link. Basically, you need a leaf blower, a 3-4' disc of plywood or particle board, a shower curtain, lots of duct tape, and a few turned parts. You could get by without turning anything, but where's the satisfaction in that?
I had thought that I could turn the main disk on my lathe (34" swing), but realized that a 42" disc would be better and a jigsaw is really a preferable tool for making such a large disc out of plywood or particle board. Those of you set up for outboard turning may disagree. The leaf blower fitting, however, was turned on the lathe, as well as the skirt disk (on the underside). I've attached a few pictures of the turned items, as well as the whole setup and an 8-second video of it in operation. (The pull string in the video was used only to get it moving; it doesn't have a forward engine yet.) In the end, I gave the hovercraft to my daughters before Christmas because I couldn't wait to try it out. I suppose it was as much for me as for them. :)
  • hovercraft.wmv
I always wanted to do something like that ever since I saw a bandsaw set up to move through a piece of wood with the wood stationary and the tool moving using a similar set up. Don't remember what he used for a blower. It was in a magazine a long time before leaf blowers came out.
Bill I think the article was in FineWoodworking or American Woodworker. As I remember it was a pretty good sized bandsaw. I looked up other articles on how to move machines using air and found some. I would bet we could find some on youtube now days.
Chicago, IL
John - cool video. Bill - if my calculations are right, using a larger 5' disc and the same 20V leaf blower will let you dance around your shop with your minmax. You may need thicker plastic than a shower curtain, though. :)
